Author Topic: quickest/easiest way to globally adjust the horizontal size?  (Read 2002 times)
adder
hi, im still in the setting up/learning stages of groovymame and it is going well but i have a question:
my crt tv doesnt have the option of adjusting the horizontal size (personally i do like slight black borders on each side when i play games). what's the quickest/easiest way to globally adjust (pull in slightly) the horizontal size in groovymame for all games? im using magic modelines, and have about 20 modelines in my registry. in mame.ini i have: monitor arcade_15, and crt_range all set to auto
cheers!
Calamity
  • Moderator
  • Online Online
  • Last login:Today at 02:50:04 am
  • Quote me with care
Re: quickest/easiest way to globally adjust the horizontal size?
« Reply #1 on: July 14, 2014, 05:28:52 pm »
Use the arcade_15 preset as a starting point:
 crt_range0  15625-16200, 49.50-65.00, 2.000, 4.700, 8.000, 0.064, 0.192, 1.024, 0, 0, 192, 288, 448, 576
Set "monitor custom" in mame.ini. Then play with the remarked values, they represent the right and left borders (yes, this order).
If you set "dotclock_min 8.0" you will get more consistent results.
Steps to create a log:
