Author Topic: Backtothearcade Neon Signs... bad transformer, need help  (Read 1729 times)
Endprodukt
  • Last login:March 04, 2026, 03:30:14 pm
« on: July 14, 2014, 11:54:40 am »
Hey,
seems like my transformer on my neon sign went bad. I'd like to replace it... problem is it doesn't say anything about the specs on the transformer itself. seems like the sticker is missing. Can anyone help out?
Problem is: Sign turns on for about 1-2 minutes, then turns off. I can turn it back on immediately.
Any help would be appreciated! :)
Re: Backtothearcade Neon Signs... bad transformer, need help
« Reply #1 on: July 14, 2014, 11:59:09 am »
Can you get some readings on the transformer while the sign is lit?
Endprodukt
« Reply #2 on: July 14, 2014, 01:10:11 pm »
I could get readings... question is which are helpful... :)
WindDrake
  • Last login:December 03, 2020, 09:49:05 pm
  • Electrical Engineer
« Reply #3 on: July 14, 2014, 05:01:54 pm »
Send a PM to Malice95 (The Backtothearcade.com Owner from BITD) on the KLOV forums about it. I'm sure he can point you in the right direction.
Don't go sticking your DMM probes on the NST. Those things are 2-15kv and will bite you something fierce.
  • Last login:March 01, 2026, 06:22:50 pm
« Reply #4 on: July 14, 2014, 07:01:07 pm »
i'd just take it to a neon sign shop. they have the experience to know how much juice it'll take to strike the tube.
that said, if it runs for a while, you have a thermal issue... FET with bad thermal heat sinking or a cold solder joint someplace that goes open when it heats up. as long as it's not potted, you can do some work in there.
pretty much the same as LCD cold cathode supplies...the fets start to go open. they spark up, and as soon as they heat up, they go open and shut off.
if it's potted. get a new one.  :dunno
Endprodukt
« Reply #5 on: July 15, 2014, 08:54:11 am »
The transformer is potted... no chance for a repair job. :(
We don't have ANY neon-sign shop in my hometown in germany, next one seems to be 120km far away... bummer :(
I will try to contact Malice95, thanks for the help guys!
« Reply #6 on: July 15, 2014, 09:28:18 am »
What? No roads in Germany? 120km is nothing. Get to driving.
« Reply #7 on: July 15, 2014, 10:24:12 am »
maybe give the shop a call see what they can suggest.
they may ask about the sign (tube diameter and approximately how long it is and what kind of gas (color)) and ask if they have a small transformer that would work for a decent price. it may be worth the drive. 120km is an hours drive...Heck in germany, what with the autobahn, 5 minutes.  :lol
if not, ask what specifications of a replacement transformer they suggest and maybe order one off ebay.
also:
http://www.bestsupply.com.hk/LoadingChartforSiettransformers.pdf
Endprodukt
« Reply #8 on: July 15, 2014, 10:40:36 am »
Well I think you guys are used to different gasoline prices. ;) Besides that I have a heavily pregnant wife that I'd rather don't let a lone for a neon lamp :D
I called the shop and they didn't seem to be very helpful actually. They're more into the big signs on Hamburg Reeperbahn that cost a lot more than my small lamp ;)
« Last Edit: July 15, 2014, 10:46:14 am by Endprodukt »
« Reply #9 on: July 15, 2014, 11:30:52 am »
Go to the store that sells cheap junk for college kids, buy some neon sign that's about the same size, steal the transformer.
« Reply #10 on: July 15, 2014, 12:15:57 pm »
we are average $1.20/ Liter here in the province alberta. with my city having the ability to get it at 1.12 right now.
lots of provinces are at almost $2.00 /liter it's a rip off all over really.
BACK ON TRACK
contact the maker of the sign first, they may have some answers... if not...
have a look at the PDF i linked, it gives you a volts/per meter of voltage required for a particular size/gas neon tube. you should be able to find someplace the colors of neon and what gases they contain for a particular color and work it out from there.
measure out the tube with string and then add a bit and find yourself an ebay transformer of appropriate size is likely your best bet..
