Author Topic: Help with directional keys  (Read 1359 times)
Richardgregory
  • Last login:November 17, 2021, 01:15:10 pm
« on: July 13, 2014, 11:24:48 am »
Ok, I am using MAMEUI64 and suddenly whenever I tap the right directional key or move the joystick right, the options come up to change volume, etc.....
I've reset all options to default to no help.
Any ideas?
Richardgregory
Re: Help with directional keys
« Reply #1 on: July 13, 2014, 12:35:24 pm »
Never mind...figured it out.  Somehow or someone went around and mucked around with the configuration keys.  ARGH!
  • Last login:Today at 10:33:42 pm
« Reply #2 on: July 14, 2014, 12:46:02 am »
. . . and this is why many people recommend not having a dedicated "TAB" button and disabling the shifted function for it, too.
If you already have a dedicated menu button, you can add a concealed SPST switch inline with the button to disable it when you aren't configuring the system.  SPST shown in "disabled" (open) position.
                      SPST switch     "Menu" button
Encoder _______/ ___________/  ____               Other daisy-chain ground connections
Ground  ________________________|_________|__________|
  • Last login:Today at 06:27:46 pm
« Reply #3 on: July 14, 2014, 12:47:30 am »
Amen, Scott-bot, amen!
« Reply #4 on: July 14, 2014, 01:19:25 am »
Thanks, but the second part of that sentence is the landmine that most I-Pac/Mini-Pac users forget to defuse.
Never underestimate the ability of kids or drunk friends to accidently trigger the shifted functions you forgot to disable.  :o
