Author Topic: glass vs. ceramic fuses.  (Read 1868 times)
Sarver Systems
  • Last login:October 07, 2020, 12:46:05 am
« on: July 12, 2014, 12:25:02 am »
pros and cons for each?
I thought a fuse was a fuse. Too much current and it blows.
I would think you'd prefer a glass fuse, since you can USUALLY tell when its blown.
And ceramic fuses are more expensive.
Ken Layton
  • Guru
  • Technician
Re: glass vs. ceramic fuses.
« Reply #1 on: July 12, 2014, 11:02:52 am »
Ceramic fuses are used in applications where heat is involved such as microwave ovens.
« Reply #2 on: July 14, 2014, 08:06:50 pm »
the ceramic fuses are often filled with sand. if a high voltage goes high load and blows the fuse, the fuse blows and the sand stops an arc from forming.
a regular glass fuse can blow, and the resulting film left on the glass from the vaporized filament can allow the high voltage arc to strike and cause further damage.
