Author Topic: Bat Top Shaft like Happ Rotary  (Read 782 times)
lamprey
« on: July 08, 2014, 01:26:01 pm »
Hi,
So I have two Happ Rotary and two GGG Super-Pro Leaf sticks set up per player. The rotaries have a thicker upper portion of the shaft to prevent it from going into the base whereas the Super-Pros have a black sleeve around the upper portion. This has two affects: 1. the sticks have slightly different heights and 2 the rotary shafts are silver and the super-pros are black.
Dose anyone know if there is drop in replacement (no modifications) bat-top shaft for the Super-Pro that will match the Happ Rotary (silver shaft, thicker at the top, etc..)? Otherwise I can buy replacement Happ handles and make a little modification. Just thought I'd check before I purchased anything.
