Author Topic: GM with VM Maker & Hyperspin Help  (Read 2731 times)
Beaps
  • Last login:July 09, 2020, 10:46:40 am
« on: June 28, 2014, 06:12:00 am »
Hi All,
Can anyone help me?
I have setup GM with the recommended 90 resolutions to enable HS to work. As soon as the HS main menu vid starts, it just resets the system. I have the codecs installed and the vids play OK outside HS.
Anyone got any ideas?
Sledge
  • Last login:August 02, 2025, 01:37:53 am
Re: GM with VM Maker & Hyperspin Help
« Reply #1 on: June 28, 2014, 06:37:52 am »
Sounds more like a Hyperspin issue... I would post this question in their forums as well if i were you..
Have you followed the guides on how to setup HS correctly?
You try re-installing it to a new folder just to make sure...
Including all the addons and videos etc..
If it was an issue with GM/VMM then HS wouldn't start at all, rather than resetting the system when the video starts...
« Last Edit: June 28, 2014, 06:39:58 am by Sledge »
Beaps
« Reply #2 on: June 28, 2014, 06:40:22 am »
Yet I have done that mate. Everything else works if I disable the vids.
Sledge
« Reply #3 on: June 28, 2014, 06:43:58 am »
What if you replace the main intro video with another one?
Beaps
« Reply #4 on: June 28, 2014, 06:45:46 am »
Tried that, even tried replacing a .mp4 back to the original .flv
  • Last login:March 15, 2026, 04:39:26 pm
« Reply #5 on: June 28, 2014, 06:49:41 am »
Have you tried disabling Flash hardware acceleration? The only way to disable it is to use Firefox, load a youtube video, right-click on it, then uncheck the option.
Beaps
« Reply #6 on: June 28, 2014, 06:52:47 am »
ahhhh that's what I was looking for, let me try that and get back to you
Beaps
« Reply #7 on: June 28, 2014, 07:36:13 am »
Works a charm, cheers dude
Sledge
« Reply #8 on: June 28, 2014, 07:40:23 am »
I had thought about that too, but discounted it as that usually results in a green preview screen, not a total system reset...
Oh well :)  :applaud:
