Author Topic: Logitech G25 or G27 Shifter and Sega Control Panel  (Read 4658 times)
codeena
  • Last login:December 03, 2023, 06:23:54 pm
  • This site is cool
« on: June 27, 2014, 12:07:38 am »
Hi all,
Has anyone tried (and hopefully succeeded) disassembling the G25/G27 shifter and fitting it into a Sega twin racing control panel shifter mount? It seems like the G25 would fit, minus the section with d-pad and the dial to switch from sequential to 6-speed. I've been using the original mount with a sequential shifter hooked up to one G25 shifter and then my second G25 shifter was mounted to the right of the seat. I would switch plugs from a serial extension cable before putting in another game. But I'd rather to use a single shifter in the original Sega control panel, but having it look as close to the original as possible.
Thanks in advance.
vandale
  • Id 10 and t error
Re: Logitech G25 or G27 Shifter and Sega Control Panel
« Reply #1 on: June 27, 2014, 03:25:07 am »
Hi, G25 is what I used:
http://forum.arcadecontrols.com/index.php/topic,138313.0.html
Any questions, point them my way
Brian74
  • Yep... I built that!!
  • Last login:Yesterday at 08:00:19 am
« Reply #3 on: June 27, 2014, 02:18:54 pm »
Also look through the stickied driving cab examples thread for some that just mount the wheel without extending the shaft.
Gbeef's build in particular.
codeena
  • This site is cool
« Reply #4 on: June 27, 2014, 07:29:56 pm »
Thanks for sharing vandale and you did an awesome job! May I ask how you secured the original outer plastic of the G25 shifter? I was thinking of screwing in the metal frame of the G25 shifter into the sega metal frame with some modification. How do you play sequential up/down-shifting games? I was hoping to be able to switch from up/down to 6spd. Thanks again
codeena
  • This site is cool
« Reply #5 on: June 27, 2014, 07:34:44 pm »
http://forum.arcadecontrols.com/index.php/topic,130821.msg1343586.html#msg1343586
Here is mine
Thanks Brian74. I had already saw your posts and I'm envious of your build. I wish I could the same but I think my skills would fall short. It's definitely ideal for me to use the G25 wheel as you did especially since I like to use the paddle shifters for F1 games and one of my faves, Virtua Racing. But I think I may keep my current setup that I've been using since the G25 came out (similar to GBeef's).
vandale
  • Id 10 and t error
« Reply #6 on: June 28, 2014, 03:03:45 am »
Thanks. I secured the shifter via 2 alloy brackets direct to the cabinet chassis. I use the paddles behind the steering wheel for sequential games :)
codeena
  • This site is cool
« Reply #7 on: June 28, 2014, 10:01:08 am »
great; thanks for the helpful info!
