Author Topic: Can anyone put a name to this grommet stick?  (Read 3453 times)
jimmer
« on: June 20, 2014, 09:54:14 am »
A lucky bonus that came with an eBay last year.
The switches have a plain front, on back they say:
Micro Switch
Freeport ILL, USA
« Last Edit: June 20, 2014, 09:56:36 am by jimmer »
Re: Can anyone put a name to this grommet stick?
« Reply #1 on: June 20, 2014, 10:01:16 am »
The stick looks like a Suzo 500, but I'm not familiar enough with them to know what the base should look like.
Shmuppers like them for the extremely short throw.
  • Last login:Today at 02:27:03 pm
« Reply #2 on: June 20, 2014, 02:11:46 pm »
Looks a bit like a Suzo 500, but lacks the swing arm restrictors and has the wrong mount hole pattern.
Also looks a bit like an MCA (Australian stick) but has the wrong mount hole pattern and a different actuator. (2nd pic, lower left)
Looked at the pics on Kowal's site here but no luck yet.   :dunno
« Last Edit: June 20, 2014, 05:09:27 pm by PL1 »
mgb
  • North East, US
« Reply #3 on: June 20, 2014, 02:43:01 pm »
The part of the body where the switches go on the Suzo appear to be the same orientation as the mounting where the one the op pictured is diagonal to it.
I know coin controls made sticks that look similar. Data East cabinets used them. I don't remember them having rubber centering grommets or square actuators but the actuator could have been swapped.
« Reply #4 on: June 20, 2014, 03:02:17 pm »
Kowal has pics of several Coin Controls sticks -- none of them looked right, either.   :dunno
« Reply #5 on: June 20, 2014, 03:59:32 pm »
The way the base is angled is just weird.  It's not even 45 degrees.
Do the switches actually sit at the same angle, or are they in the same orientation as the main joystick mounting plate?
If at an angle, it would almost have to be designed for a specific cabinet.
Virtua Fighter had the joysticks at weird angles, but none of the pictures I found look like those joysticks.
That grommet looks old school.
« Reply #6 on: June 20, 2014, 05:15:14 pm »
+1 on this being an unusual stick.
We need more :pics  to narrow it down.   ;D
jimmer
« Reply #7 on: June 20, 2014, 06:10:53 pm »
it's dark now, so all I can do is give you higher res.
I should have said it's not on kowal's site, save you the trouble of checking.
It's basically one of these but with a suzo style dome on the top housing, and suao style lever.
http://www.kowal.itcom.pl/ArcadeParts_pliki/joyW8WMJ.htm
mgb
  • North East, US
« Reply #8 on: June 20, 2014, 07:20:25 pm »
Does the centering grommet actually go to this stick because that looks like a wico grommet. But the stick may be a cheap chinese knock off
« Reply #9 on: June 20, 2014, 08:00:24 pm »
I have a pair of MCAs. Those aren't them.
mgb
  • North East, US
« Reply #10 on: June 20, 2014, 08:43:42 pm »
The underside of the mountingplate and the grommett look like wico. Maybe just a no name knock off
jimmer
« Reply #11 on: June 22, 2014, 07:09:41 am »
hmmm
There was a UK company Euromax Ltd. Selling Suzo sticks but often branded as euromax and not showing the suzo name in adverts.
This one has Suzo name  http://www.worldofspectrum.org/showmag.cgi?mag=C+VG/Issue037/Pages/CVG03700188.jpg
Wico made a euro styled version, called Euromax.
