Author Topic: drilled an unintended hole in my CP. Need help fixing  (Read 2569 times)
Locke141
  • Never grow up.
« on: June 18, 2014, 12:08:59 pm »
MDF'er,
I was drilling a pilot hole from the bottom of my CP for the female screw inserts and I drilled a to fare :angry: .
My whole CP is going to be repainted in Aug so its not the end of the world. does any one have any ideas on the best way to fix the hole?
I'm so close to being done.
Generic Eric
Re: drilled an unintended hole in my CP. Need help fixing
« Reply #1 on: June 18, 2014, 12:12:06 pm »
I used an 8 hole pattern for my 7 hole layout and ended up with an extra hole  I filled a button sized hole with wood putty.  You can tell its their even after the paint, but it adds a neat touch.  Its as strong, if not stronger than the rest of the panel.
  • Last login:Today at 04:59:53 am
« Reply #2 on: June 18, 2014, 12:39:31 pm »
Install the threaded insert if you haven't already done that.
Carefully cut away the erupted area on the top of the CP.
Install the joystick and screws to ensure that the next steps don't make a plug that gets pushed out when you install the joystick screws.   :angry:
Use a piece of tape/thin weatherstripping to keep the Bondo from getting on/into the threads of the screw and insert.
Fill with Bondo and let it dry completely -- you may want to do this in 2 layers, depending on the depth.   :dunno
Remove the screws and joystick so they don't get dusty during sanding.
Sand the bondo smooth.
Prime and paint.
Enjoy.   ;D
« Last Edit: June 18, 2014, 12:54:19 pm by PL1 »
« Reply #3 on: June 18, 2014, 01:23:10 pm »
+1 on PL1's method.  Bondo holds better than wood filler in my opinion.  It also cures within 5 - 10 minutes.
D
« Reply #4 on: June 18, 2014, 03:09:16 pm »
D
its pretty much exactly how I fix the busted ass cabs I buy.
Locke141
  • Never grow up.
« Reply #5 on: June 18, 2014, 03:32:53 pm »
Sweet,
I hope I can find Bondo here in Tanzania. If not I'll pick some up next month when I am back in the US.
Thanks guys,
B
ChanceKJ
« Reply #6 on: June 18, 2014, 11:06:03 pm »
D
...---steaming pile of meadow muffin---. Really?
My experience with bondo is, well, non-existent.  When you say "holds better" are you speaking to the adhesion to the wood? or does it make for a more solid material. My experience with wood filler is it can be damaged easily and chip off.
« Reply #7 on: June 19, 2014, 09:18:48 am »
Its like patching with concrete once its fully cured. Well that might be a stretch but its significantly better than wood filler.
« Reply #8 on: June 19, 2014, 09:58:31 am »
This.
It's pretty amazing stuff.  Smells while your putting it on (fumes), but works great.  Easy to sand.  Easy to paint over.
D
  • Last login:Yesterday at 12:10:06 pm
« Reply #9 on: June 19, 2014, 10:14:10 am »
I've never had very good luck with wood filler.  The patched spot is always visible and noticeably different from the rest of the surface no matter what I do.
+1 on Bondo
  • Last login:Today at 01:15:50 am
« Reply #10 on: June 19, 2014, 10:23:35 am »
I flat out quit using wood filler after I read about mixing saw dust with wood glue and water.  I have no doubt that bondo is better but DIY sawdust cream can't be beat cost-wise.
kahlid74
  • Gaming for a better future!
    • GamersAnon
« Reply #11 on: June 19, 2014, 11:28:00 am »
I still use wood filer for most stuff but for stuff I really care about or are harder to work I use Bondo.  It's superior to wood filler through and through.
