Author Topic: How about this one? Is THIS an isolation transformer?  (Read 1637 times)
Sarver Systems
  • Last login:October 07, 2020, 12:46:05 am
« on: June 08, 2014, 07:42:35 pm »
From what I can tell:
110VAC in (side marked 117V/PRI/0V)
110VAC out (side marked 117C/1A/0V)
18VAC out (side marked 9V/0V/9V) with a center tap for 9VAC if needed.
Am I correct?
Is 1A enough to power a monitor?
« Last Edit: June 08, 2014, 07:46:36 pm by Sarver Systems »
ed12
Re: How about this one? Is THIS an isolation transformer?
« Reply #1 on: June 08, 2014, 07:52:35 pm »
look's like a 1amp iso to me
with a 18v ct secondary also
so lower 2=117vac
upper 3 = 18vac ct,which wuld mean 9 on either side of the ct
ed
Sarver Systems
« Reply #2 on: June 08, 2014, 07:55:24 pm »
Is 1A going to be enough to power, say, a 27" monitor? It would only be used for testing, nothing permanent.
ed12
« Reply #3 on: June 08, 2014, 08:16:06 pm »
eh 50/50
just to plug in and run for a min or so u should be ok
but not for a normal ussage ie a day or 2
ed
Sarver Systems
« Reply #4 on: June 08, 2014, 08:37:33 pm »
I'd have it plugging in for 1/2 hour or so, enough to calibrate color, H-hold, etc...
ed12
« Reply #5 on: June 08, 2014, 08:54:33 pm »
ya i have ran them for a full shift 14hr's
then i un-plug them..
would not sujest u put it into a cab for day to day use,but to each there own
ed
Sarver Systems
« Reply #6 on: June 08, 2014, 08:58:21 pm »
Thanks ed, appreciate the info!
  • Online Online
  • Last login:Today at 05:27:05 am
« Reply #7 on: June 08, 2014, 10:13:33 pm »
If you can refrain from touching the monitor while powered on, you don't need the isolation transformer.
