Author Topic: What type of screw is this?  (Read 3653 times)
MamedInCanada
  • Last login:February 02, 2016, 06:23:09 am
  • Still Learning...
« on: June 07, 2014, 07:49:58 pm »
I believe this is some kinda security screw. I've seen it on control panels also, this one was from the speaker cover. About 5/8" in length if I recall. I got some 3/4" Phillips cross slots from Rona / Home Depot but just don't like the look.
What's the proper name for it?
Where do you get them from?
Dawgz Rule
  • Last login:August 22, 2024, 07:18:55 pm
  • The more people I meet, the more I like my dogs
Re: What type of screw is this?
« Reply #1 on: June 07, 2014, 07:55:17 pm »
Torx Security Screw.    Not sure if you could get them at a big box store but I am sure you could Google it.
MamedInCanada
  • Still Learning...
« Reply #2 on: June 07, 2014, 08:06:02 pm »
Thanks...I kept looking up hex head
  • Online Online
  • Last login:Today at 12:13:02 am
« Reply #3 on: June 07, 2014, 08:11:18 pm »
+1 on Torx security screw or "pin in head".
Not sure the exact size that you need, but probably something around T15 or T20.  :dunno
ed12
« Reply #4 on: June 07, 2014, 08:34:51 pm »
another +1
>+1 on Torx security screw or "pin in head".<
we use them on golden tee golf's >marquie's<
as a rule we break out the :pin: and just use a t15 or t20
ed
Slippyblade
« Reply #5 on: June 07, 2014, 09:01:35 pm »
I got a small set of bits for these security screws from the local auto parts store.  They're used in automotive ignitions a lot these days.
Sarver Systems
  • Last login:October 07, 2020, 12:46:05 am
« Reply #6 on: June 10, 2014, 03:10:26 pm »
Costco carries a 100+ piece set of bits that covers pretty much ANY security bit you'll encounter on these machines. $20, and it comes in a nice carrying case! It does not come with a handle, so you need to supply one.
« Reply #7 on: June 10, 2014, 04:37:09 pm »
Also goes by the name of 6-lobe. You can see if there is a Fastenal Store near you. They should have it.
If you got a harbor freight near ya, they less than $10 (before 20% off coupon as well).
Monkeyvoodoo
  • Last login:November 16, 2024, 01:36:41 am
  • I swear I can stop at one. Or two.
    • threefoldhorse Custom
« Reply #8 on: June 11, 2014, 12:53:31 am »
Judging by your screen name there is no harbor freight near you. You could try Canadian Tire or Princess Auto if you have one in your area. I got my (cheap) set from PA.
Sarver Systems
« Reply #9 on: June 11, 2014, 11:40:41 am »
Harbor Freight has the smaller set for $10.
I opted for the Costco set since it has more bits, and contains multiples of the standard Phillips, hex, star, etc...
Sarver Systems
« Reply #10 on: June 11, 2014, 11:51:28 am »
My set is 208 pieces, that's why I couldn't find a pic of it!
Here it is:
« Reply #11 on: June 11, 2014, 12:10:46 pm »
Right on! Looks nice!  :cheers:
