Author Topic: Are these good dado bits?  (Read 2343 times)
thehammer12
  • Last login:October 24, 2021, 01:46:34 pm
  • Arcade Breaking Specialist
« on: June 06, 2014, 04:22:06 pm »
kahlid74
  • Gaming for a better future!
    • GamersAnon
Re: Are these good dado bits?
« Reply #1 on: June 11, 2014, 08:53:36 am »
I have not, I prefer to stick with brand names when it comes to the RPM's spinning on my router.  I'd be interested to know the manufacturer of those.
spoot
  • Destroyer of electronics
« Reply #2 on: June 11, 2014, 10:36:53 am »
I prefer Whiteside or Eagle myself.......but price is more than twice as much.  But if you're not gunna use them alot (for many cabs) you should probably be fine.
thehammer12
« Reply #3 on: June 12, 2014, 12:21:58 pm »
Already ordered them, Ill keep you guys posted.
lamprey
« Reply #4 on: June 12, 2014, 12:58:07 pm »
Weird, my reply from a couple of days ago, seems to have never made it..
At any rate, I'm sure they'll work just fine. I don't know if there are similar straight bits with a different name. But, I have a version like the ones you posted as well slightly different ones. The ones like you posted have the bottom cutting-edge (?) with a space in between. So, I found it a pain to use with my plunge router if I needed to start in the middle of  the material, not on the edge. If I was starting dado from the edge, then they work just fine. I don't know if there is a special name for those types of straight bits, but now I know to look for something slight different if I need to start with a plunge. Or maybe it's all in my head..  ;D
I'm not 100% sure, but I think these are like the "other" bits I mentioned:
http://www.cpotools.com/bosch-85265mc-3-4-in--x-1-1-4-in--straight-carbide-tipped-router-bit/bshn85265mc,default,pd.html
