Author Topic: IPAC4 and simultaneous lshift/rshift lctrl/rctrl  (Read 853 times)
« on: June 03, 2014, 09:29:19 pm »
I'm having a very peculiar problem with my IPAC4.
Basically, If i press and hold the LCTRL button, the RCTRL won't press., same with shift.
But, every other key appears to work just fine when pressed simultaneously with a second key.
The actual "shift" key is mapped to player1 start, which is just "1" so that doesn't appear to be a factor.
I've tried redownloading the keymappings several times and that process works, but the keys still don't press in combination.
I've also unloaded or disabled every background app I can think of that might effect this (Autohotkey, 3rvx, etc).
Still no luck.
Anyone else run into anything like this? I thought maybe there was a flash update available for the IPAC but I didn't see one on Ultimarcs site.
