Author Topic: WTB: pair of red ball-top joystick shafts (long)  (Read 852 times)
big10p
  • Last login:May 01, 2023, 01:46:23 pm
  • Mmmm, arcade classics!
« on: June 01, 2014, 05:26:59 am »
Hi
I want to swap-out the shafts in my dual stick control panel for red, ball-top ones (a la Robotron). I'm hoping I can do this, rather than replace the entire joysticks. My joysticks are Happ Supers with a length from the bottom of the handle/knob, to the end of the shaft of 10cm. The shaft diameter is about 8mm.
Does anyone have a pair of these they would be willing to part with?
Thanks in advance.
P.S. I'm in the UK
[edit] No longer need. I've ordered 2 new ball top joysticks, instead. Cheers.
« Last Edit: June 04, 2014, 08:26:14 am by big10p »
