Author Topic: Wood thickness  (Read 4967 times)
sollyscomputers
  • Last login:March 06, 2019, 01:31:51 am
  • Jukebox? check! Now on to cocktail cab
    • Softweb Developments
Wood thickness
« on: May 31, 2014, 03:48:37 pm »
Hey guys,
Just your thoughts.  I'm about to start building a cocktail cab and I was going to use 16mm particle board, but wondering if 12mm (1/2") would be good enough?  If 12mm is OK then Can you still get T-moulding for that size?
Cheers!
John
Slippyblade
Re: Wood thickness
« Reply #1 on: May 31, 2014, 03:50:56 pm »
T-Molding in 12mm size is almost impossible to find in colors other than black or white.  At least that's what I've been told by others.  Not looked myself.
mattgold
  • Tinker 'till it's right...
Re: Wood thickness
« Reply #2 on: May 31, 2014, 07:50:31 pm »
He speaks the truth:
http://www.t-molding.com/store/home.php?cat=1
PERHAPS you could get it elsewhere - I just don't know where.
-M
  • Last login:Today at 12:04:31 am
Re: Wood thickness
« Reply #3 on: May 31, 2014, 08:04:48 pm »
Are you sure you want to use particle board?   :dunno
sollyscomputers
Re: Wood thickness
« Reply #4 on: May 31, 2014, 10:07:18 pm »
only because it's lighter. I know mdf is stronger but also heavier. I think for an in doors project should be ok.  Might just stick to 16mm maybe.
Re: Wood thickness
« Reply #5 on: May 31, 2014, 10:26:14 pm »
Since you want it to be lighter than MDF, consider using plywood.   ;D
shponglefan
Re: Wood thickness
« Reply #6 on: May 31, 2014, 11:38:10 pm »
I don't think particle board is very ideal if you are planning to use T-Molding.
sollyscomputers
Re: Wood thickness
« Reply #7 on: June 01, 2014, 02:55:21 pm »
Thanks guys I will look into plywood
John
happyfunball
  • Last login:December 11, 2015, 07:49:39 pm
Re: Wood thickness
« Reply #8 on: June 04, 2014, 05:59:11 pm »
use plywood, it'll make your life much easier.
Slippyblade
Re: Wood thickness
« Reply #9 on: June 04, 2014, 06:12:26 pm »
I recently discovered MDO.  It's plywood in the middle with a thin layer of MDF on the outsides.  Great stuff, half the weight of MDF and it edges and finishes just like MDF.  Nice stuff.
sollyscomputers
Re: Wood thickness
« Reply #10 on: June 04, 2014, 06:14:04 pm »
I will ask my local guys and see if they know of it.  Sounds perfect!!
  • Last login:November 22, 2025, 08:32:45 pm
Re: Wood thickness
« Reply #11 on: June 05, 2014, 01:45:33 am »
Did you actually buy this locally?
kahlid74
  • Gaming for a better future!
    • GamersAnon
Re: Wood thickness
« Reply #12 on: June 05, 2014, 09:54:52 am »
MDO is the jam.  Occasionally the Home depot by my work has it but usually I have to order directly from the Wood Mill guys.
As others have said here, use Plywood and if you can spare an extra 10-20$ per sheet, use sanded ply.  It will make your life much easier.
Thickness wise you could probably get away with 12mm (~1/2") but make sure you have support braces inside.  1/2" is not as sturdy obviously so a couple of 1x6/2x6/2x4's on the inside for braces should be plenty enough to bear the load.
Slippyblade
Re: Wood thickness
« Reply #13 on: June 05, 2014, 11:31:16 am »
Yep.  Heldt Lumber on 7th St south of Bethany Home has it.  Not bad on pricing either.  In 1/2" and 3/4".  They've got 4x8 sheets of 1/2" and 3/4" melamine as well.
Re: Wood thickness
« Reply #14 on: June 08, 2014, 12:38:14 pm »
Nice, I'm close to Heldt's and have bought from them before. Thanks for the tip!
