Author Topic: Ipac wiring question(s) just to be sure...  (Read 1960 times)
ts
  • Last login:April 08, 2016, 03:01:29 pm
« on: December 06, 2003, 12:51:55 pm »
Hey everyone.  I am plodding alo9ng on my build and am now wiring my control panel to the ipac.  If my sore  sore fingers will allow me to keep typing (I am crimped and quick connected to death over here :) ), i have a few questions...
1.)all of my daisy chained wiring from the "common" terminal of the switch wire to the ground terminal on the ipac correct?
2.)I have 4 dedicated buttons to wire (exit, pause, etc.) in the current mame configuration they are a shift function.  To make them seperate functions all to themselves, I reprogram my ipac (move the jumpers, etc.)  So can I just pick any unused inputs on the ipac to wire them to and specify them in my program?
3.)I have two mouse trackball buttons.  Where are they wired to.  Maybe the same inputs as my 4 way dedicated shoot and jump buttons?  Which would also be the same input as two of my buttons for my 8 way player 1 control.  that seems like a lot of wires to one or two inputs.  And would this allow these buttons to double as right and left click this way?
4,)Lastly, whhat in puts are best wire my two side pinball buttons to?
Thanks anyone who has some insight or advice
Tiger-Heli
    • Tiger-Heli
Re:Ipac wiring question(s) just to be sure...
« Reply #1 on: December 06, 2003, 02:10:52 pm »
Correct!
Pick any unused inputs on the I-PAC and wire them in.  For MAME, you have the choice of re-programming the I-PAC or re-programming MAME.
For example, let's say you are not using P1B7, which is I think "C" in the default I-PAC program.  You can either connect your Pause button to this and Re-program the I-PAC so this input send P . . . or leave the I-PAC alone and in MAME change Input (All Games) so Pause uses the "C" key.  Either way.
Option 1 is fine for MAME, but if you want them to right and left click in windows, you need to wire them to whatever the trackball interface is using for buttons.  What interface do you have for the t-ball (hacked mouse, opti-pac, ME4, Happ, etc?)
The pinball games in MAME are probably using L Ctrl and L Alt, but I'd want to verify that.  If you're gonna be using Visual Pinball, I think you can assign the buttons to anything anyway, so it really doesn't matter I-PAC wise.  If you are using any Pinball emu's that don't allow you to remap inputs, then wire the buttons to the corresponding I-PAC inputs, unless there isn't one, in which case, you'll be re-programming the I-PAC, so again, it doesn't matter.
ts
« Reply #2 on: December 06, 2003, 03:16:10 pm »
Thanks for the help.
I am using a happ trackball with usb interface to the computer...
Advice on this welcome.
Thanks again
Tiger-Heli
    • Tiger-Heli
« Reply #3 on: December 06, 2003, 03:23:17 pm »
Thanks again
If you mean this one: http://www.happcontrols.com/trackballs/565600xx2.htm
then it comes with wires for the buttons already connected.
ts
« Reply #4 on: December 06, 2003, 05:59:18 pm »
got it.  thanks
one last one.
when wiring the coin door so the computer recognizes a coin being dposited, do I hhod the coin door directly to the coin 1 and coin 2 inputs on the ipac.  On the coin door it appears to be three connections/terminals (albeit bigger than the .187 size)  I am assuming one is the common and the other two no and nc like the other microswitches.  Do I include those two commons in my ground daisy chain wires to the ipac and hook on of the others (the normally open) to the ipac coin 1 and coin 2 inputs?
That sound right?
MinerAl
  • Last login:December 15, 2025, 06:28:31 pm
  • duck
« Reply #5 on: December 08, 2003, 03:43:14 pm »
Yup.
Just treat the coin switches as any other switch.  Make sure your ground goes to the Common and your I-PAC to the NO (or vise versa).  You can (should) use the same ground as the other buttons and switches.
