Author Topic: invalid media path error - config is ok  (Read 5156 times)
ZoOl007
  • Last login:August 02, 2020, 12:03:38 pm
    • RGBcommander
« on: May 27, 2014, 03:31:32 pm »
Hello,
I've got a weird issue - already tried a lot of stuff to no avail.
I'm setting up dolphin and I'm getting invalid media error with regards to the rom path.
Anybody got this problem and if so - How on earth did you solve it?
It's just another bug I'm afraid
rgds
JDFan
Re: invalid media path error - config is ok
« Reply #1 on: May 28, 2014, 04:05:16 pm »
One thing to check --  In preferences in MA (CTRL -P) go to the configuration tab and make sure that the "path to media" selection box is set to Long not short.
ZoOl007
    • RGBcommander
« Reply #2 on: May 28, 2014, 05:11:13 pm »
thanks for your answer. I managed to sort it out. I took nebula but it seems it doesn't work with it. I reproduced exactly the same on another maximus install... so, went on with gcx(?) vertex and it worked - took tgx16 - worked - weird... the config in the ini differs from the rest but hey :) I've got gamecube running ...
rgds
drahcir
  • Last login:January 25, 2015, 10:16:46 am
« Reply #3 on: January 07, 2015, 11:30:11 pm »
try this tutorial when i wnet home.tnx
