March 20, 2026, 06:07:39 pm
What are you trying to do, exactly? Maybe freehand something and post that and we'll see what we can do.
Ah, you're not using guides. For instance if you want a 1" radius corner you would drag a guide 1" in from the two edges that form the corner then use the arc tool to connect the guide/edge intersections. Then drag the arc out till it snaps to "tangent at vertex".
