Author Topic: How can you hook up an XBOX (Gen1) to a PC monitor ?  (Read 1745 times)
mike boss
« on: May 22, 2014, 01:53:28 pm »
Looking over in the projects thread I got inspired to dig out 1 of 6 "altered" Gen1 XBOX units I have in storage. I know I can use a KADE for the controls, but can I use a PC monitor ? If so how ?
I will confirm now, I've been lazy and not done much looking online.
Can one of these readily available RGB to VGA adapters via eBay do the trick ?
  • Last login:Today at 08:16:32 pm
Re: How can you hook up an XBOX (Gen1) to a PC monitor ?
« Reply #1 on: May 22, 2014, 01:58:58 pm »
This is the only way to do it and have everything work in HD:
http://www.ebay.com/itm/Xbox-Original-NEOYA-X2VGA-Multi-Screen-Adapter-67242-/281343425813?pt=US_Video_Game_Controllers&hash=item41815ffd15
I wouldn't part with mine for less than $100.
apfelanni
  • Last login:February 18, 2019, 01:55:28 pm
« Reply #2 on: May 22, 2014, 01:59:47 pm »
neoya adapter , mayflash yuv>vga , hd box or snowmans vga cable . all of em doin well with a vga pc monitor , no matter if its a crt or a tft-lcd .
the neoya is not the only way , but the adapter works fine . 25 $ is a very reasonable price . they usually sell on ebay here around 30-50 eu .
« Last Edit: May 22, 2014, 02:02:24 pm by apfelanni »
mike boss
« Reply #3 on: May 22, 2014, 02:18:43 pm »
Thank you guys.
HD is of no concern to me.
Something cheap and easy is more of what I'm looking for.
mike boss
« Reply #4 on: May 22, 2014, 02:24:15 pm »
Sorry, which adapter do you mean ?
mike boss
« Reply #5 on: May 22, 2014, 03:03:12 pm »
The extra dapater I have is like this (if not this exact.....I'm unsure).
I was hoping I could use something  like this.
http://www.ebay.com/itm/New-RGB-CGA-EGA-YUV-to-VGA-Arcade-HD-Video-Converter-Board-abb-/190854005923?pt=LH_DefaultDomain_0&hash=item2c6fc904a3
apfelanni
« Reply #6 on: May 23, 2014, 01:48:42 am »
its the cheaper pcb version of the hd box pro . yuv > rgb and by choice with or without scaling . as i explained , there are many ways to put out 31 k vga or higher . in case u need 15 k u may hack a scart cable with rgb output .
« Last Edit: May 23, 2014, 01:51:28 am by apfelanni »
mike boss
« Reply #7 on: May 23, 2014, 08:14:44 pm »
Thanks all.
Going to find the one I have in the basement and then look to order the HD XBOX wires.
