Author Topic: onsite backups - input needed  (Read 1858 times)
TopJimmyCooks
« on: May 20, 2014, 10:10:30 am »
I have an external hard drive that I could connect to my router and use as a backup.
What's the best bet for software that can automatically, incrementally back up selected folders on several different pc's (win 7 home, and XP) and store it on that usb drive?  Acronis for $89?  Would need 3 user license.
Thanks.
CCM
Re: onsite backups - input needed
« Reply #1 on: May 20, 2014, 10:29:30 am »
Thanks.
I use the free version of syncback for simple backups.    They also have paid versions... here's a link to the comparison of their different versions, maybe you'll get lucky and the free version will suit your needs.
http://www.2brightsparks.com/syncback/compare.html
The built in Windows 7 backup and restore is actually really good, but I don't think you can backup to a network location if you are using Windows 7 Home.   You need Win 7 Pro for that.
TopJimmyCooks
« Reply #2 on: May 20, 2014, 10:59:15 am »
Yeah it would be $85 x each pc to upgrade and id like to have the option to backup the kid's document folders as well.  an Xp and a vista box.  Plus, I'd love to be able to run it all without installing software on every box.  I'll check out syncback.
I feel like the dang helpdesk at my own house with 7 pcs/4 tablets and 3 phones.
EDIT :  Installed syncback and checked it out.  If it works it will be perfect.  Thanks for the tip.
« Last Edit: May 20, 2014, 11:20:56 am by TopJimmyCooks »
spoot
  • Destroyer of electronics
« Reply #3 on: May 20, 2014, 11:10:06 am »
Bacula....but that might be a bit overkill for your purposes.
spoot
« Reply #4 on: May 20, 2014, 11:11:13 am »
Bacula....but that might be a bit overkill for your purposes.  And would require client install on each........and the tablets/phones would be an issue I guess.
TopJimmyCooks
« Reply #5 on: May 20, 2014, 11:22:37 am »
not backing up the tablet and kindles.  just managing them from time to time.  mostly deleting the stupid flash games when their storage gets filled.
ark_ader
  • I glow in the dark.
« Reply #6 on: May 20, 2014, 04:25:14 pm »
