Author Topic: Buying Optocouplers  (Read 998 times)
bimm25e
  • Last login:July 30, 2024, 08:44:11 am
Buying Optocouplers
« on: May 13, 2014, 01:43:39 pm »
So I need to close a 24VDC circuit when a Jamma button is pressed, I think an optocoupler is going to be my best friend here But I don't know how to shop for them, I want to make sure I buy one that will be able to trigger on 1V and support a 24V circuit on the other side
nitrogen_widget
Re: Buying Optocouplers
« Reply #1 on: May 13, 2014, 03:21:45 pm »
I would look at circuits used to trigger SSR's by the Raspberry PI & Arduino communities.
You will need a transistor & a 2nd power source to trigger most solid state relays because 1v probably won't be enough.
here is an example.
http://forums.adafruit.com/viewtopic.php?f=8&t=48936
