Author Topic: BlazBlue Continuum Shift Taito Type X2 stuck in letterbox  (Read 2781 times)
s8n187
  • Last login:October 10, 2025, 12:50:25 pm
« on: May 03, 2014, 09:45:45 am »
hi members , i can only get this to run in Letterbox even though its in full screen and not in a window.
i cant figure out how to run this as it should , below is a Youtube video proving how it should be run.
anyone know how to achieve this ?
twistedsymphony
  • Last login:February 03, 2024, 11:13:51 pm
  • Play stupid games... win stupid prizes.
    • solid-orange.com
    • CollectorsEdition.org
Re: BlazBlue Continuum Shift Taito Type X2 stuck in letterbox
« Reply #1 on: May 05, 2014, 09:30:24 am »
This is a widescreen game... AFAIK it only ever displays in 16:9 and if you try to run it at a 4:3 resolution it will appear letterboxed.
The video you linked is a widescreen video which is why it fills the whole screen.
What resolution do you have it set to?
« Reply #2 on: May 05, 2014, 10:21:33 am »
Are you using some kind of third party loader software that forces a resolution?
Try setting a different resolution there.
s8n187
« Reply #3 on: May 05, 2014, 10:28:25 am »
i just typed out a reply and ive had to retype a new one due to BadMouth's response..............
i tried in ArcadePC Loader the res 1920x1080P and boom BBCS runs perfect !
i was using the loader Taito Type X Launcher by Yiori which doesnt have a res changing function in the GUI.
problem solved guys ,  now its party time !
thanks for your help its appreciated
twistedsymphony
    • solid-orange.com
« Reply #4 on: May 05, 2014, 02:51:42 pm »
FWIW most TTX games have an external config file that allows you to set the resolution. This is useful if you're launching games from a front end application without a GUI launcher.
