Author Topic: MDF edges  (Read 3846 times)
s_busby_uk
  • Last login:August 22, 2017, 02:28:51 pm
MDF edges
« on: April 22, 2014, 09:31:53 am »
What's the best method for making sure the exposed edges of MDF board don't look obviously "MDFy" when the thing is painted, or will the paint sort that out? Obviously I'm having T-molding on the sides, but currently the base of my machine - which is T-shaped - has two exposed sides, and I'd ideally like for them not to be visible when the thing is finished.
TopJimmyCooks
Re: MDF edges
« Reply #1 on: April 22, 2014, 10:29:15 am »
get the edges smooth and sanded how you want them.  then use a putty knife and apply a thin but continuous layer of gypsum wallboard joint compound over the edge.  when that dries and you sand it smooth it will fill the "grain" of the mdf and make the edge smooth and able to take paint nicely  like the surface.  Just a thin layer.
s_busby_uk
Re: MDF edges
« Reply #2 on: April 22, 2014, 10:30:22 am »
Perfect, thanks TopJimmyCooks
Caparo8bit
  • Last login:April 28, 2018, 02:13:32 am
  • Hyperspin/Maximus
Re: MDF edges
« Reply #3 on: April 23, 2014, 12:16:54 am »
Other easy fix wood glue mixed with water (small amout) i use this to seal also sides of MDF ones is dry you can sand the piece to get a smooth surface.
kahlid74
  • Gaming for a better future!
    • GamersAnon
Re: MDF edges
« Reply #4 on: April 25, 2014, 08:18:28 am »
If you follow the two coat rule you won't notice the MDF.  Two coats primer, two coats finish and you're all set.
Re: MDF edges
« Reply #5 on: April 26, 2014, 01:21:55 pm »
Instead of their eyes being drawn to the MDF, you could make all the other work so crappy they never even notice the edges look bad.
matt4949
Re: MDF edges
« Reply #6 on: April 26, 2014, 01:54:22 pm »
Yeah, That's how I do it
No, really I use the water and elmers 50/ 50.
s_busby_uk
Re: MDF edges
« Reply #7 on: May 03, 2014, 06:46:37 am »
Would this work with No More Nails glue?
jennifer
Re: MDF edges
« Reply #8 on: May 03, 2014, 03:52:00 pm »
 Automotive glaze putty works nice too, thin coat then primer, more geared towards a solvent based finish... But I don't quite understand, You are going to put a T molding over it right??
s_busby_uk
Re: MDF edges
« Reply #9 on: May 03, 2014, 04:39:28 pm »
No this isn't for the t molding sides - basically the base of my unit is more like a t shape so there are exposed mdf edges at the base if the "t"
