Author Topic: Installing Windows XP 32 bit and 64 bit on H81M-E33 Intel 1150 Motherboard  (Read 34671 times)
69mustang
  • Last login:March 20, 2015, 12:31:40 am
I successfully installed Windows XP 32 bit and 64 bit on an MSI H81M-E33 Motherboard with an Intel 1150 Pentium G3220. CRT_Emudrivers  installed correctly and Groovymame works wonderfully. Here is a link to the drivers I used, I'm sure they could be used with other 1150 motherboards as well.
Chipset Drivers: https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23061
Intel Management Drivers: https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22092&keyword=intel+management+engine&DownloadType=Drivers&lang=eng
Realtek Ethernet: http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=13&PFid=5&Level=5&Conn=4&DownTypeID=3&GetDown=false
Realtek HD Audio: http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=24&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
I didn't bother looking for drivers for the Intel Smart Connect, since it is unnecessary. All it does is connect to the internet while the PC is asleep and update drivers and programs for you.
I hope this helps someone out with their build.
« Last Edit: April 20, 2014, 03:32:58 am by 69mustang »
  • Last login:Today at 04:59:00 pm
Hi 69mustang, thanks for reporting this.
Logix
  • Last login:April 18, 2016, 03:23:53 pm
Thanks a lot - it really helped me. I also used the VGA drivers from the following link, which work perfectly :
https://downloadcenter.intel.com/download/22875/Intel-HD-Graphics-driver-for-Windows-XP32-Embedded?product=80939
Hope this helps someone else !
