Author Topic: Vulnerable to Heartbleed Bug :(  (Read 6278 times)
CthulhuLuke
  • Last login:May 22, 2025, 01:03:42 am
  • old school
    • CthulhuLuke's Arcade Parodius
« on: April 10, 2014, 03:28:29 pm »
Hey guys, been lurking here a loooooooong time.
Anyway, just wanted to let you know that arcadecontrols.com is vulnerable to the Heartbleed bug :( Someone who has the ability needs to update the server software on here to get a non-vulnerable OpenSSL server.
Louis Tully
Re: Vulnerable to Heartbleed Bug :(
« Reply #1 on: April 10, 2014, 03:31:01 pm »
« Last Edit: February 12, 2015, 05:02:47 pm by Louis Tully »
bochi
  • Last login:April 10, 2014, 04:20:18 pm
« Reply #2 on: April 10, 2014, 03:36:22 pm »
Its bad :(
(This is CthulhuLuke, I can't see any passwords but you get cookie dumps :/ :/ )
404
« Reply #3 on: April 10, 2014, 06:10:55 pm »
yep, just tested it myself. Admins need to update asap.
  • Last login:Yesterday at 01:01:52 am
« Reply #4 on: April 10, 2014, 06:12:18 pm »
Looks like the bug affected your signature file line.
If this gets Tapatalk fixed, go for it!
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:February 11, 2026, 06:56:49 am
« Reply #5 on: April 11, 2014, 08:13:15 am »
I've updated the OpenSSL.
I didn't realize anyone was using https to access the forum though. Are folks?
CthulhuLuke, 404 - still seeing vulnerabilities?
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
« Reply #6 on: April 11, 2014, 08:39:16 am »
I assumed that the login page was https but it is not.  Is it an option to require SSL for the login page?
404
« Reply #7 on: April 11, 2014, 08:43:07 am »
Still reports as vulnerable but this time around i couldn't dump cookies.
saint
« Reply #8 on: April 11, 2014, 09:03:23 am »
Thank you - what tool are you using to assess the vulnerability?
--- John St.Clair
     Project Arcade 2!
404
« Reply #9 on: April 11, 2014, 09:27:24 am »
^^ heartbleeder
https://github.com/titanous/heartbleeder
Although i think the biggest issue here is that your cert was signed over 2 years ago. I'd try to get a new cert (your host should be more than accommodating during this situation)Best method to patch this up is to tweak settings and then just use some of the more common, online testers to check your settings as you go along.
http://filippo.io/Heartbleed/
https://lastpass.com/heartbleed/
If you happen to have a cert by geotrust, they have created a quick form that allows you to get a new cert very fast
https://products.geotrust.com/orders/orderinformation/authentication.do
saint
« Reply #10 on: April 11, 2014, 09:38:28 am »
That's the thing I have to puzzle out - I don't have a cert that I'm aware of :) I may have a self-signed cert, sirwoogie may have set something up, but I've never purchased a cert for the server here.
--- John St.Clair
     Project Arcade 2!
404
« Reply #11 on: April 11, 2014, 10:01:47 am »
yeah, I would ask sirwoogie to get more details on the cert situation. There is definitely something there but it is definitely old.  Also make sure the heartbeat extension is enabled.
CthulhuLuke
  • old school
« Reply #12 on: April 11, 2014, 10:29:13 am »
fox_heartbleedtest.py says you are no longer vulnerable.  ( http://foxitsecurity.files.wordpress.com/2014/04/fox_heartbleedtest.zip )
That is what I used to get bochi's cookie, you could basically set it up in a loop dumping memory and looking for cookies that contain SMF20=
Your certificate is definitely self-signed. The issuer is sirwoogie@gmail.com.
404
« Reply #13 on: April 11, 2014, 11:54:43 am »
strange. when i checked earlier this morning it was showing up as still vulnerable. Now i just checked with heartbleeder and it times out.  ???
  • Last login:Today at 08:37:03 am
« Reply #14 on: April 11, 2014, 12:14:49 pm »
Does the wiki need to be patched, too?
« Reply #15 on: April 11, 2014, 06:14:15 pm »
What does all this have to do with Tapatalk????  >:D
