Author Topic: LED 12v ( SOLVED BY JDFan)  (Read 2291 times)
Caparo8bit
  • Last login:April 28, 2018, 02:13:32 am
  • Hyperspin/Maximus
« on: April 07, 2014, 11:52:42 pm »
Can some one help me o this one. I have a 12v LED strip that i need to connect to a house oulet. Thanks.
« Last Edit: April 25, 2014, 05:56:09 pm by Caparo8bit »
JDFan
Re: LED 12v
« Reply #1 on: April 08, 2014, 12:19:31 am »
How many amps of 12V power -- do you plan to use a computer system or go directly to house current ? If using a computer and you have an adequate PSU you could just use a 12V molex plug to power it - If going direct to wall outlet you'll want a 12V AC adapter that has sufficient Amperage rating similar to these :
Caparo8bit
  • Hyperspin/Maximus
Re: LED 12v
« Reply #2 on: April 08, 2014, 12:22:59 am »
Im using a laptop i think theres no way to get 12v so im going in to a house outlet let me show you the one i have . Just plug and play right?
JDFan
Re: LED 12v
« Reply #3 on: April 08, 2014, 12:34:19 am »
As long as they do not need more than 24Watts ( Watts = Amps x Voltage so 12V 2 Amp adapter like that shown will run up to 24W of LED lights.
Caparo8bit
  • Hyperspin/Maximus
Re: LED 12v
« Reply #4 on: April 08, 2014, 12:42:25 am »
those are 12v LED Daytime Running Lights for cars i dont know if that gives you a better idea. Ne ways im going to try it . Thanks >:D
