Author Topic: virtuaNes dialog box question  (Read 1374 times)
ts
  • Last login:April 08, 2016, 03:01:29 pm
« on: December 03, 2003, 05:18:25 pm »
I am trying to get virtuanes running through mamewah.  all seems to be well except when i load a game before the game loads i get a dialog box stating the following...
"Because a NES header is illegal there can be the thing that does not work normally.  Do execute?"  Then gives me a yes or no button.
I hit yes and the game loads up fine.  However, is there a way to disable this screen.   Should I try an earlier version of virtuanes as possibly this was put into the newer releases.
TalkingOctopus
    • My Arcade
Re:virtuaNes dialog box question
« Reply #1 on: December 03, 2003, 06:08:11 pm »
That is a problem with the NES rom you are loading.  Sometimes roms with illegal headers do not work.  Not every rom should come up with that message.  Unfortunately, I do not know of anyway to disable the warning message.
