Author Topic: MaLa sizing and resizing- do I need to create a different layout per resolution?  (Read 2533 times)
benarcade
  • Last login:October 13, 2023, 04:59:32 pm
I created a layout with a background image that's 1024x768. Do I need to run it on a monitor set to that same resolution? Because when I run it on my 1280x 720 for example, the image resizes, but the text and snaps don't - so the elements are in the wrong places.
Or is there a setting that fixes this?
Or should I just create a different MLL for each resolution I plan on using?
