Author Topic: KORTEK KTX26 + ATI x600 + crt_emudriver - < 20 video modes  (Read 1680 times)
zorrobandito
  • Last login:October 04, 2025, 12:11:09 am
    • Zorro's Classic Games
« on: March 13, 2014, 08:55:16 am »
This is a new PC build and my testing shows that the display is working but with a lot less than the 160 modes suggested - more like 20.
Not sure which step I'm missing. I did the following:
1. Installed ATI card driver from the crt_emudriver package.
2. Unzipped CRT_Emudriver
3. Edited VMMAKER.INI and specified MameExe location. Changed Monitortype from "CUSTOM" to "GENERIC"
Ran C:\VMMAKER\VMMAKER.EXE.
Rebooted.
I mostly followed the instructions here, which worked very well.
You can see from the attached screenshot of the available modes that most of them are different frequencies of 640x480.
Should I be getting any more modes with that hardware combo? Do I need any more? I'm using groovymame, which games should I test?
  • Last login:February 12, 2026, 10:34:58 am
Re: KORTEK KTX26 + ATI x600 + crt_emudriver - < 20 video modes
« Reply #1 on: March 13, 2014, 01:36:40 pm »
Hi zorrobandito,
If you're using a recent version of GM, make sure to download the latest VMMaker available here (1.3c): http://mame.3feetunder.com/windows-ati-crt-emudriver/
Older versions are not able to parse the new XML format from recent MAME versions.
zorrobandito
« Reply #2 on: March 13, 2014, 10:19:31 pm »
Thanks Calamity, I'll download and try it tonight!
zorrobandito
« Reply #3 on: March 14, 2014, 09:40:11 am »
Great suggestion, that worked a treat!
The only lingering problem I have is that I am sometimes returned to the Hyperspin menu in the resolution of the previous game.
apfelanni
  • Last login:February 18, 2019, 01:55:28 pm
« Reply #4 on: April 05, 2014, 05:04:59 pm »
after  installing  the ati drivers there should be around 1xx resolutions available in windows.  u can try a normal guimame to check out the available resolutions , or arcade osd .
« Last Edit: April 05, 2014, 05:12:12 pm by apfelanni »
