Author Topic: BYO... pinball?  (Read 12555 times)
grafixmonkey
  • Last login:October 16, 2010, 08:16:50 pm
  • must... tear self... away from... Tron...
    • My graphics/arcade/circuits site!
BYO... pinball?
« on: December 02, 2003, 08:05:14 pm »
I have three pinball games in my basement that are in need of restoration, and while I'm at it I thought it'd be fun to try building my own pinball machine.  (well, just a simple one, to see how they work.)  Anyone else on this forum do stuff with pinball machines?  I could use a few pointers on how to get started.
I've got a Black Knight game with some of the flippers kind of going weak, and a Gorgar that has some targets that won't come back up and some knockers that don't knock, and a Bally bowling game that won't stop ringing its little xylophone inside.  That, and all of them need some work on the play surface cuz they're starting to show some wear.  I'll post some pics of them later.  We'd never owned pinball games before when we bought them, so if there's maintenance you have to do to keep them nice, we haven't been doing it.   :-[
-- See my grafix, circuits and cab on my
-- new arcadey page:  http://www.bkgrafix.net
paigeoliver
  • Awesome face!
Re:BYO... pinball?
« Reply #1 on: December 02, 2003, 09:13:26 pm »
I do have a Bally Hawaii Bingo type pin at home that I was thinking about refitting with flippers and a different playfield. Mainly because Bingo pins are about 10X more complicated than regular pins, and Hawaii was the most complicated Bingo pin ever made.
Xiaou2
  • Last login:January 17, 2026, 10:44:40 pm
  • NOM NOM NOM
Re:BYO... pinball?
« Reply #2 on: December 02, 2003, 11:30:45 pm »
 Original Black Knights go for good money on ebay.  Id say sell it there before ripping it to smithereens... as that would just be wrong.   If it were something else like 'judge dread'... id say blow it up... as that game stunk imop.
(if the price is low enuff... and your close enuff, I might be interested in you b.kinght... email me:  xiaou2@hotmail.com)
 Theres a lot of sites out there on pinball restoration.  Some are very detailed.  For instance... one showed that for weak flippers, you can unwind some of the coil a bit.  (But that also may just need a new coil sleeve or genral cleaning and joint lubrication... or coil replacement...).
  If your machines have electrical issues.. theres usually places you can take them to for reapirs.  Look in the phone book.  Also... look for local pin'heads (collectors), as they usually know some great places for repairs.
  As for the playfields... these always go bad after a lot of use.  However... theres protective measures that can be taken.. and things to do to revamp them like new.
  The Black Knight 2000 I have has awefull cracks / chips / and missing graphics on the field.   I finally found a printing place that will scan and print such a thing.  My plan is to scan in my feild... then take the data home to edit and clean it up - adding in the missing works from pics from a friends machine.   Then have the scan reverse printed (with UV fade resistent inks) on clear plasic film (4mil)... and then that gets cold laminited.  This new art would then get placed over the old field -providing beauty and a brand new hyper fast surface for the ball to roll on.  Im guessing the prints will cost anywhere from 150 to 300$ with all these options + scanning.
 (Theres cheaper soluitions for people who just want something to look 'ok' and function 'ok'... like just grapping a large piece of clear mylar and overlaying it over the feild 'as is)
  Ive also seen a site that a guy made a gothic pinball from a toasted machine.  Its not a project for the non-electrical genious I tell ya.  Id say youd be better of restoring to learn how the things work mechanically before attempting to build something thats more complicated.  Also... you should know how to fix and maintain your new creation anyway least it share the same fate.
  I also do want to build my own pinball though.  My thoughts were to make it using a smaller marble sized ball thus it take up less space... and cost a lot less to build.
 Im not electronically savvy enuff to figure out the high power coil issues tho... well, that and all the rest too! (but that being the worst of it all)
  I made a proto long ago (to avoid the 24+ volt high power situation)  that used a high speed motor with a string attached to a wooden lever.  When the ball hits the contact, it would turn the motor on for a sec thus blasting the ball across the room via the lever.  However... I think this might fail over time... and may suffer from lag or burning out the motor..ect.
 Hopefully someday someone will create a Build your own mini-pinball kit... that can use a pc as the backboard, link for multiple player games / scrore transfers..ect., and for programming the custom machines.  One could even make replicas of some machines... then possibly use modded pinmame to be the brain of your replica...  dream!
  To conclude this... a word of warning.   Pinballs take a Lot of maintaining to remain in great shape... and even then... will still degrade.   They are expensive to buy, fix, restore, and even to buy parts for.    They require good mechanical knowledge... and the desire to tinker for hours to take appart several assemblies just to clean / repair things that are 2 to 3 levels deep on the playfeilds.
  With that said... they are great fun to play  : )
  some cool links:
http://www.marvin3m.com/fix.htm
http://www.woodman.org/pinballlinks.htm
« Last Edit: December 02, 2003, 11:58:49 pm by Xiaou2 »
allroy1975
  • Last login:November 11, 2023, 08:51:48 pm
  • I'm a dork!
    • Matt's Mame
Re:BYO... pinball?
« Reply #3 on: December 03, 2003, 01:45:55 am »
Those guides are GREAT.  Those are both Solid State pins, wich in my opinion makes them much easier to work on.  If you can soldier and de-soldier you can probably fix any problem you've got with a Solid State pin.  I just got a Black Knight 2000 and was having problems with the center drop targets.  I did a little work and found some optical eyes on the drop target.  Got the manual, found the optos I needed ordered 3 new ones $3 each (I didn't think that was bad, most places wanted 6-9 for them!) and got a new chip for the thing at radio shack.  Desoldiered the old optos, put in the new ones..bingo.  Works like a champ.  It might sound a little complicated, but imho it's not that hard to work on the electronics of a SS machine.
As far as the playfields go, is the playfield cracked?  or work down to the wood?  You may be able to get it looking and playing great again by buying some playfield cleaner.  Clean it up and then give it a good coat of wax and it'll play great!  Or if it's all beat to hell, just bring it to my house and i'll take it off your hands.  Losing your pin will be your pennance for not taking care of it in the first place.   :P
Allroy
They have the FAST Ms. Pac-Man!  MOM!  Can I have a quarter!??
allroy1975
  • I'm a dork!
    • Matt's Mame
Re:BYO... pinball?
« Reply #4 on: December 03, 2003, 01:56:15 am »
oh, and as to building your own Pin...
When I picked up my Black Knight 2K, I started reading a bunch of interviews with Steve Richie (the guy who designed BK, BK2K and a number of other HUGELY popular games) and he said that it takes about a year to develop a good pin.  I'm guessing that's for him.  Someone who knows what they're doing.  If you're talking about building a copy of a real pinball machine, that might be more possible, but there's SO much artwork on those playfields.  Pinball is so much more beautiful than Vids.  Vids just don't have the space...not to mention, pinball is a more skilled game.  No one programmed how the ball will react.  It's more random.  No patterns to learn.  No bugs to exploit.  I dunno.  On the other hand...practice a shot for an hour or so and you shouldn't miss it very often.  :)
I'm rambling at this point.  I just wanted to post and mention that thing about Steve Richie saying that it takes a year to design a good pin.  It also sounded like they use some kind of "peg" board?  IIRC that's what it was called.  It sounded like it was a playfield with no art where they could just move stuff around pretty easily, so they didn't have to make a new playfield etc. each time they wanted to play the new design.
Jeez...I just keep thinking....
Maybe if you built your table in Visual Pinmame...or whatever that program is....maybe that would work out well...who knows.
I thought I had a great Idea a while back of building a big pin cabinet with removable playfields.  just pull the whole game.  have a computer in it that interfaced with the new playfield.  you could play any pin, as long as you had a playfield for it.  now that I think of it again...maybe it's not such a great idea.  :)
Allroy
paigeoliver
  • Awesome face!
Re:BYO... pinball?
« Reply #5 on: December 03, 2003, 03:21:02 am »
Allroy
Already possible, "The Ultimate MPU board" supports like 30 different pins. I think if you had that you could swap playfields in and out. Although playfields are the single most expensive component of a pin, so it might not make any sense to do so.
bionicbadger
  • Last login:October 01, 2012, 10:37:26 am
  • Big Deal
    • Mame Cabinet Page
Re:BYO... pinball?
« Reply #6 on: December 03, 2003, 10:38:41 am »
There was some discussino a couple weeks ago on rec.games.pinball on this and some guys were talking about building a KIT to sell, you can probably look at google for it.  The biggest problem is the software.  The harware part is easy, but getting a cpu to recognize what happens when a specific switch is closed is the tough part.
allroy1975
  • I'm a dork!
    • Matt's Mame
Re:BYO... pinball?
« Reply #7 on: December 03, 2003, 10:52:51 am »
right that's just the MPU though.  Youd still need the lamp and solonoid drivers for each game.  Since they're not all the same it wouldn't work...I don't think.
Ken Layton
  • Guru
  • Technician
Re:BYO... pinball?
« Reply #8 on: December 03, 2003, 10:54:22 am »
I've been repairing pinballs since 1976. The main problem I'm seeing lately is tons of connector failures. Pins actually are breaking off inside the connector housing either from metal fatigue, corrosion, or burning!
paigeoliver
  • Awesome face!
Re:BYO... pinball?
« Reply #9 on: December 04, 2003, 12:28:25 am »
I think a lot of them actually are the same. My Victory (Gottlieb System 80 B) and my Force II both use the same driver boards, I can swap them between them, and the victory still works, and the Force II still doesn't work the same way it always didn't work.
Xiaou2
  • NOM NOM NOM
Re:BYO... pinball?
« Reply #10 on: December 04, 2003, 01:36:20 am »
 If anyone has a bk2000... Im going to get mine scanned in for a reverse print on 4mil clear mylar type material (with cold lamination protection).  (will be cleaning it up in photoshop myself)
 Im currious to know if anyone else would like a copy.  Im guessing that it will cost from 150 to 250$ range.  Ill know more soon as Im still in the process of getting the quote and details...
 Some benefits reviewed:
1- no old dirty 'Lifting' mylar.  no dirt lines from smaller mylar pieces edges.
2- no faded or missing gfx.  Nearly Impossible to 'ball wear' them ever again! + uv resist inks.
3- perfect flat surface.  no bumps, gouges, cracks... ect. to slow the ball
4- perfect vibrant colors! - no pitting to allow staining of art either.
5- High Gloss shine!
6- easy to maintain and clean
7- easy to change if needed
8- keep original paintwork protected (increases collector value)
9- will force to clean and adjust the machine to perfection durring the dis/assembly process
10- how cool will it be to have a factory new look playfeild!   ^-^
  I think this is a lot better option than whats currently available.   Its also safer and easy to reverse unlike other methods that could permanately damage the feilds... and cost about the same if not much more.
  Email me at  xiaou2@hotmail.com  if your interested in revamping your bk2000 as well.
(  Im also trying to get the New'er plastics set copied over so that one can put the decals under custom cut plexi...Currently I have the old set... but have a friend that has the new and hopefully will allow me to scan his for the task)
paigeoliver
  • Awesome face!
Re:BYO... pinball?
« Reply #11 on: December 04, 2003, 03:33:34 am »
Don't they still make the parts for BK2000? It is a fairly newish game isn't it?
GodSend25
  • Last login:February 16, 2005, 03:18:04 pm
Re:BYO... pinball?
« Reply #12 on: December 04, 2003, 10:20:24 am »
Anyone in the Toronto area have a pin they are looking to unload? Something from the early 80's is good :)
Xiaou2
  • NOM NOM NOM
Re:BYO... pinball?
« Reply #13 on: December 04, 2003, 04:35:51 pm »
 Was made in 1989.  And no.. no playfeilds are produced anymore.  I doubt any non-standard parts are produced for these anymore as williams stopped pinball production.  I think they sold the company... and now make slot machines?
Ken Layton
  • Guru
  • Technician
Re:BYO... pinball?
« Reply #14 on: December 04, 2003, 06:31:06 pm »
Williams didn't sell the company. They had several divisions: Bally/Midway/Williams pinball, Midway video games, Williams Gaming. Williams closed the amusement divisions (pinball & video) and concentrated on the Gaming division. All they make today are video slot machines.
slycrel
  • Last login:June 25, 2025, 07:42:34 pm
  • Mmm... Portal.
Re:BYO... pinball?
« Reply #15 on: December 04, 2003, 06:39:21 pm »
  A bit offtopic...  but is there any company that creates pinball machines NEW anymore?  I know of a few that do refurbs and such...  but I don't know of any that create new tables.  Anyone know?  Just curious.
Ken Layton
  • Guru
  • Technician
Re:BYO... pinball?
« Reply #16 on: December 04, 2003, 06:43:23 pm »
There's only one remaining USA pinball manufacturer and that's Stern Pinball, Inc. The most recent machines they have made are The Simpson's Pinball Party and Terminator 3. Soon to be released is Lord of the Rings. I believe there are still several pinball manufacturers in Europe and Australia, but those machines don't usually show up here in the USA.
