Author Topic: new full blown genesis v1 with rgb break out plug composite over clock etc. MI/U  (Read 1002 times)
northerngames
  • Trade Count: (+18)
Hi, Up for sale is my new original v1 full blown sega genesis game console lot.
please read to understand why this cost more then your usuall old scraped up one's.
this is from my own collection and was pulled from a new sealed box after all these years and I went through it and did all the mods you can pretty much.
The modded flight stick was also brand new in the box when I did the mod.
here is what is included and then I will explain what has been done to this set to make it a top shelf console.
pictures are of the acutal items you will recieve.
new custom v1 sega genesis console
new composite a/v cable cord
new power cord brick
new controller
new custom genistick
new full break out plug for true rgb video out
desert strike like new
urban strike like new
jungle strike like new
ok so onto what has been done to the console and genistick.
!!!! CUSTOM GENISTICK !!!!
genistick button function has been changed around the included strike heli games.
the stock function had the button layout all weird so it was rewired so now the main single button in the front is for the chain/machine guns and the button on the left is for the 2nd strength medium rockets and the button on the right is now the 3rd strongest rocket.
this now can be reverted back by just swapping to wires on the inside.
!!!! CUSTOM GENESIS CONSOLE !!!!
Composite L&R outputs for a rca style stereo plug
overclock switch to speed to remove video and sound lag in certain memory hungry games
regional switch allows use of imports by toggle switch
real full break out cable plug to straight wire rgb for the best display possible.
composite video output jack
rd module and rf sheilding completly removed for RGB adjustment board this can be seen in the pic where the module use to be and now has a pot in each hole.
one adjust h hold and the other does color for rgb fine tuning to take it another step further.
A S-video output and parts are installed but no finished and needs to be wired in still but all the hardware is there already.
hate to see if go and it's hard to find these new anymore plus new and custom>>>....grab this while you can!!!
I am also selling off a nice custom dreamcast and playstation so check my other listings.
asking $135.00 on this it is new and modded and not something that has been lurking in a basement for 20 years lol.
