Author Topic: Sega Touring Car PC Version pedal help  (Read 2453 times)
Boomslang
« on: March 02, 2014, 03:51:14 am »
Hi
I relise that this is emulated well via m2emulator. However network doesn't work but PC Version does, problem is that it doesn't allow me to select my pedals on PC Version. Accerate and Brake work via clutch pedal and I can't make it be the correct pedals. Anyone know how to fix this?
segarally
  • Last login:March 15, 2019, 03:35:06 am
  • Very Long Easy Right...Maybe !
Re: Sega Touring Car PC Version pedal help
« Reply #1 on: March 04, 2014, 09:32:48 am »
If I remember correctly with the logitech gaming software 5.10 everything worked (gas and brake pedal)...
Boomslang
« Reply #2 on: March 05, 2014, 04:02:13 am »
Thanks man! I checked it out and found you need to set combined pedals then it works.  Also interesting that fanatec wheels have force feedback but logitech g25 does not
  • Last login:Today at 06:32:05 am
« Reply #3 on: March 05, 2014, 09:07:29 am »
Nearly all older games require the pedals to be combined, as does Demul emulator.
In fact the only thing I've found that doesn't support combined pedals is M2emulator.
I wish I'd made that the default when I started.  It would have saved me from having to create a custom profile for every old game I install.
Strange about ffb on the G25 not working since they're both direct input devices.
I think it should work.  Is the G25 the only device connected?
Sometimes these old games will only send the ffb to device #1.
Boomslang
« Reply #4 on: March 05, 2014, 01:14:43 pm »
Yep I've got them all installed same way and all by themselves across 4 pcs
