Author Topic: Help w/ Kega Fusion controller configuration w/ X-arcade  (Read 9663 times)
tastysoil
  • Last login:October 24, 2017, 02:06:58 pm
« on: February 28, 2014, 10:05:25 am »
Hey guys,
Hoping someone has a fix for a problem i'm having trying to configure the controls in the Kega Fusion Sega emulator. Every time I click the "define" button in the Genesis/32x/Sega CD controller pref. it asks you to press control for "up" and when you do, it immediately jumps past "down" without letting you define it, then when you press "left" it jumps past defining the key for "right" and so on… It even does this if you try and define the keys by using only the Keyboard as well, so I doubt it's an issue with the X-Arcade Joystick.. Has anyone else had this problem?  ???
Thanks for any ideas!
P.S. I should mention that i'm trying this on the newest build, as well as an older build and have the same issue assigning keys to the controls
« Last Edit: February 28, 2014, 02:02:28 pm by tastysoil »
tastysoil
Re: Help w/ Kega Fusion controller configuration w/ X-arcade
« Reply #1 on: February 28, 2014, 06:03:31 pm »
I found this video explaining a fix for a "usb game controller"
Unfortunately, This doesn't help with the X-Arcade tank stick that I have though, because it isn't seen as a "game controller" in windows -- each button on the X-arcade is mapped to a key on the keyboard. Has anyone else had this problem? Hoping you guys have some suggestions…
Thanks in advance!
DarthMarino
  • Last login:December 17, 2025, 10:53:45 am
« Reply #2 on: February 28, 2014, 07:00:42 pm »
I use my X-arcade with Fusion all the time with no issues.  I have version. 3.64.  Maybe play around with the keyboard settings in your control panel.  Perhaps it's repeating the letters too quickly. You can always play around with the settings in Fusion.ini and change them manually.
tastysoil
« Reply #3 on: February 28, 2014, 07:07:27 pm »
I'm using 3.64 also...
DarthMarino, any chance you could send me your already configured Fusion.ini? It'd be a huge help
