Author Topic: Need help with this chassis swap  (Read 1145 times)
redfivexw
  • Last login:March 11, 2025, 03:54:00 am
« on: February 22, 2014, 01:41:27 pm »
I have done a ton of 19" chassis swaps using wei-ya chassis, i tried this swap today and had a bit of an issue, i think i read everything right on the chassis and readings, but it still smoked.  The picture was good for about 5 minutes (nice stable picture) but then it scrambled and i smelled smoke and shut it down.  Below are my photos of my readings, etc.  I bought a wei ya 825 chassis to replace a wells gardner chassis on a 25" monitor.
mgb
  • North East, US
Re: Need help with this chassis swap
« Reply #1 on: February 22, 2014, 03:43:08 pm »
Did you have it powered correctly through an isolation transformer?
Although if not, I don't think you'd get 5 minutes
Edit: that's a zenith k7000 (built for WG) so it should have already had an ISO transformer.
« Last Edit: February 22, 2014, 03:47:16 pm by mgb »
ed12
« Reply #2 on: February 22, 2014, 04:30:03 pm »
sorry bud look again
thats a "hot" chassic
need's isolation
ed
redfivexw
« Reply #3 on: February 22, 2014, 06:43:33 pm »
 Yes, it was wired correctly, the original chassis was a wg 7000.   I have wired tons of 19 " chassis, not many 25"' wanted to make sure I did not miss anything before I sent it back.
mgb
  • North East, US
« Reply #4 on: February 22, 2014, 07:02:06 pm »
need's isolation
ed
Yes I know
That's what I said.
I was just stating that seeing it is a k7000, it should already have an iso
