Author Topic: Cancelling intro video in Mala  (Read 4000 times)
Slippyblade
« on: February 17, 2014, 05:02:30 pm »
So, I've got Mala all setup and it's working great.  I've got windows hidden with Mala as the shell.  Using Keith Apicary's Neo-Geo music video as an intro video and it all works great.
Except one thing.  When I have a keyboard plugged in, you can cancel out of the video no problem.  The controls don't do it though.  I am using a Xin-Mo encoder which is seen as two gamepads.  Sooo, it seems that gamepad input doesn't cancel the intro video, only keyboard input.  Is this correct and I've done something wrong?
Thanks in advance!
SGT
  • Last login:May 31, 2025, 10:10:32 pm
Re: Cancelling intro video in Mala
« Reply #1 on: February 17, 2014, 07:50:27 pm »
I just tried it with Mala and a wireless Xbox 360 controller.  I used joytokey to map a gamepad button to Right-Shift.  This enabled me to to cancel the intro video with that button.  Not sure if there's a cleaner solution or not.
Slippyblade
« Reply #2 on: February 17, 2014, 07:55:26 pm »
Totally forgot about JoyToKey!  When I get home from work I'll do that.  Thanks!
« Reply #3 on: February 17, 2014, 08:37:35 pm »
why not just disable the intro vid?
Slippyblade
« Reply #4 on: February 17, 2014, 08:59:55 pm »
Cause I like the intro vid.   :dunno
Slippyblade
« Reply #5 on: February 18, 2014, 01:54:00 am »
Hmm, JoytoKey would work except for one thing... I've got Mala config'd as the shell, so it loads before anything else.  So JoytoKey isn't loaded at that point and can't process joystick input. Back to the drawing board.
SGT
« Reply #6 on: February 18, 2014, 12:39:07 pm »
Can you run joy2key as a service using SrvStart or something similar?
Slippyblade
« Reply #7 on: February 18, 2014, 12:51:51 pm »
Worth a try.  I do that tonight.
