Author Topic: Mame.ini volume not working?  (Read 7013 times)
fleskebacon
  • Last login:November 22, 2024, 01:58:55 pm
« on: February 17, 2014, 05:11:15 am »
Some of the games I play in Mame are noticably louder than others (dkong for example), and I'm looking for a way to store the volume settings so I don't have to adjust all the time.
As I understand, the line "volume 0" in mame.ini controls this, and by putting the line "volume -15" in dkong.ini I thought this would do the trick. But it doesn't.
The "volume" line doesn't seem to have any effect, whether I adjust it in mame.ini or any other ini-file.
Why?
Running Mame 0.152.
baritonomarchetto
  • Last login:Today at 01:26:56 am
Re: Mame.ini volume not working?
« Reply #1 on: February 17, 2014, 06:01:16 am »
Volume control works for me (MAME 0.151). Try setting a way lower volume (i.e. "-50") and see if it works for you.
Try also the slider control (TAB menu) and see if it actually slows down the volume
fleskebacon
« Reply #2 on: February 17, 2014, 07:42:35 am »
The slider works just fine. And the ini file doesn't do anything, no matter what volume I put in it..
Connorsdad
  • Last login:May 18, 2024, 04:28:42 pm
« Reply #3 on: February 17, 2014, 07:52:34 am »
Use the slider menu and lower the speaker volumes not the overall volume, play a quick game and exit. I did this yesterday on a game that was louder than my others and it saved the volume level.
« Reply #4 on: February 17, 2014, 08:57:45 am »
MAME does not save the main volume setting when you exit the game.
It will save the volume settings in the service menu of the game (F2 by default)
and on the speaker slider adjustments in MAME's in-game menu (TAB by default)
fleskebacon
« Reply #5 on: February 17, 2014, 10:26:32 am »
Yey, the speaker slider trick worked. :)
But I still don't get what the "volume"-line is doing in mame.ini, when it's good for absolutely nothing?
baritonomarchetto
« Reply #6 on: February 18, 2014, 10:17:32 am »
It works as it should for me (MAME 0.151)
fleskebacon
« Reply #7 on: February 18, 2014, 01:58:04 pm »
Could be a 0.152-issue then? Will try 0.151 and check.
