Author Topic: WTB: Wico 4 way red ball leaf joystick  (Read 2489 times)
slbailey
  • Last login:October 04, 2016, 12:47:43 pm
« on: February 12, 2014, 10:27:31 am »
Starting my next cabinet build and apparently these things have become hard to find.  If anyone knows where I can find a good Wico 4 way leaf stick (pac man, donkey kong, galaga, etc.) let me know.
Steve
Ginsu Victim
  • Comanche, OK -- USA
Re: WTB: Wico 4 way red ball leaf joystick
« Reply #1 on: February 12, 2014, 03:51:02 pm »
Do you specifically need Wico? www.groovygamegear.com has excellent 4-way leafs.
deadmoney5
  • Last login:February 03, 2020, 11:02:02 pm
  • I don't feel tardy
« Reply #2 on: February 12, 2014, 05:02:15 pm »
I have a NOS 4-way Wico that I never use, but it's a light blue ball.
chopperthedog
  • Last login:Yesterday at 03:40:23 pm
« Reply #3 on: February 12, 2014, 06:25:57 pm »
Might help to give your panel type (wood or steel) for shaft length purposes. The 3 games you mentioned all used completely different designs none of which were made by wico.
good day.
slbailey
« Reply #4 on: February 13, 2014, 06:20:42 pm »
Was going to be a wood panel since that's what my last one was.  I wanted Wico because that's what I had last time.  Maybe I'll do more research into other options before committing.  Didn't think home made steel panels were a realistic possibility.
« Reply #5 on: February 13, 2014, 09:35:35 pm »
good day.
and Galaga was a two way :)
Slippyblade
« Reply #6 on: February 13, 2014, 09:51:43 pm »
With the availability of and relative ease of access to CNC and laser/water-jet cutting, I'd say they are very realistic.  Probably not cheap, but realistic.
Paul Olson
    • Paul's Arcade
« Reply #7 on: February 17, 2014, 11:07:43 am »
Definitely not cheap in low quantities, but they are certainly possible. Last year, I ordered 30 joystick mounting plates (mount the joystick to the plate, then mount the plate to a wood panel), with a center hole and 8 threaded studs. They were $10 each at that quantity. I needed a couple of different plates, so I got quotes last week. In quantities under 5, the same plate is $38.40.
A standard layout would be 16 holes and 8 threaded studs. Add in a trackball, and it is 4 more studs and a hole.
It is still only one setup though, and that is the expensive part. If there is bending to shape at the edges, that would be a bit more. I would guess that it would be about $100-150 for a 24" panel.
Brian74
  • Yep... I built that!!
« Reply #8 on: February 17, 2014, 07:48:31 pm »
I have one, what are you willing to pay? pm me if you are interested
« Last Edit: February 17, 2014, 07:52:22 pm by Brian74 »
Brian74
« Reply #9 on: February 20, 2014, 05:05:35 pm »
So I take it, you arent interested?
