Author Topic: mame 1.52 laggy  (Read 3283 times)
haku99
  • Last login:January 04, 2015, 07:58:17 pm
mame 1.52 laggy
« on: February 10, 2014, 07:43:23 pm »
Hey All
So I'm using mame 1.52 with no nag/highscore compiled into it.
I am finding that games in general run like they're in slow motion (well not quite, but slower than on my quad core computer)
The sound stutters too.
I tried using another mame, such as the one with the graphical interface, and it seems to run about 10% better.
My mame PC is a dell inspiron 531
-amd athlon 64 x2 6000+ (3.0ghz)
-4 gigs of ddr2 ram
-win7 64 (i tried win 7 32 bit and the lag remains)
-HD: 7200 rpm toshiba drive
-on board video card
-on board sound
I searched around and believe that any dual core CPU above 2.2ghz, should run most games decently, but I am finding this is not the case.
Can anyone give me any suggestions on improving performance?  I know that a dedicated GPU won't do much, but what about another gig of ram?
The PC is dedicated for mame use and has no other applications etc. on it.
cheers
« Last Edit: February 11, 2014, 05:01:13 pm by haku99 »
Re: mame 1.52 laggy
« Reply #1 on: February 10, 2014, 07:48:28 pm »
Do you have HLSL enabled in mame.ini?
That is pretty GPU intensive and onboard graphics can't usually handle it.
EDIT: also what games in particular are you talking about not running full speed?
haku99
Re: mame 1.52 laggy
« Reply #2 on: February 10, 2014, 08:03:18 pm »
pretty much any mame 1.52 game
-Cadillacs and Dinosaurs
-golden axe
-final fight
-cave games (dodonpachi, i know this one is a bit more graphic intense
-etc...
went into mame.ini
HLSL_enable was set at 0, I changed it to 1
same issues
arquillos
  • Last login:Yesterday at 08:48:07 am
Re: mame 1.52 laggy
« Reply #3 on: February 11, 2014, 12:00:33 am »
As BadMouth said, leave HLSL alone (0).
Your computer is able to run that games at full speed so there is an issue with your on board video card or maybe with on board sound card drivers...
Please post the on board video card you´ve got (e.g. intel GMA...) and driver version your are using.
Disable any graphical effects you may have configured in mame.
Try running mame in full screen. It will give you better perfomance.
Try disabling sound to see if it´s a on board sound card problem related
Try running another Mame version (e.g http://shmupmame.wordpress.com) to test if your 152 version is somehow broken.
« Last Edit: February 11, 2014, 12:02:13 am by arquillos »
Ginsu Victim
  • Comanche, OK -- USA
Re: mame 1.52 laggy
« Reply #4 on: February 11, 2014, 01:48:21 pm »
It's 0.152, btw. Seventeen years later and we're only on POINT one five two. Crazy...
haku99
Re: mame 1.52 laggy
« Reply #5 on: February 11, 2014, 05:00:39 pm »
Hello
I have not enable anything in mame video settings, it's just default
-mame is always running in full screen, which causes the sound stutter and video lag, when I played it in a smaller window, the game ran normally!
I tried using other versions of mame (groovy mame, etc.) but same result in full screen
even games like donkey kong jr have sound stutter and video lag
I have attached a picture of  my sound and video drivers
-disabling sound in device manager did not help
haku99
Re: mame 1.52 laggy
« Reply #6 on: February 11, 2014, 11:27:14 pm »
WELL
I ended up putting a nicer GPU in it and now everything runs flawlessly!  No stutters whatsoever.
Strange though, I read that mame is suppose to be CPU dependant rather than GPU, but my experiences say otherwise....
thanks for the help!
arquillos
Re: mame 1.52 laggy
« Reply #7 on: February 12, 2014, 07:07:18 am »
Very strange, as you said MAME is CPU dependant. Only HLSL filters are GPU dependant.
Re: mame 1.52 laggy
« Reply #8 on: February 12, 2014, 07:45:35 am »
When you use an on board GPU it pulls CPU cycles and uses your system RAM. More often than not putting a GPU in and not using the on board will improve performance, especially around the era of CPU you are using.
Ginsu Victim
Re: mame 1.52 laggy
« Reply #9 on: February 12, 2014, 04:52:42 pm »
Oh yeah, tossing a video card in there versus using on-board is almost always going to create an improvement.
liquid8
  • Last login:January 08, 2026, 02:01:16 pm
  • I working on it.. it'll be a while.
Re: mame 1.52 laggy
« Reply #10 on: February 12, 2014, 10:29:53 pm »
You had old (2009) ATI drivers.. that will make a big difference. CPS1/etc should be fine with the onboard on that machine I would think. If you needed to go back to the onboard for some reason, make sure the drivers are up to date.
haku99
Re: mame 1.52 laggy
« Reply #11 on: February 12, 2014, 11:00:36 pm »
i have 2 of these PCs with same specs
I'll test it out when I set up the other comp and let you know!
