Author Topic: look what i got today!!  (Read 7121 times)
SpatzST
  • Last login:April 18, 2021, 05:29:46 pm
« on: February 03, 2014, 06:37:05 pm »
A nice big box of goodies!
All pics are here.. moved them to organize. >> http://s223.photobucket.com/user/SpatzST/library/arcade
Just gotta grab some wood and get cutting!
« Last Edit: February 08, 2014, 12:33:31 am by SpatzST »
Re: look what i got today!!
« Reply #1 on: February 03, 2014, 06:50:54 pm »
Looks like a box from GGG.  That never gets old.   :cheers:
Slippyblade
« Reply #2 on: February 03, 2014, 07:22:23 pm »
As silly as it sounds, those button wrench things are worth their weight in gold.
SgtSlaughter
  • Last login:March 02, 2021, 10:38:50 am
« Reply #3 on: February 03, 2014, 07:55:54 pm »
I'll second that!  I know I was excited when I got a similar package from GGG... Now I'm saying to myself... why did I get the LEDs!  TOO MANY WIRES! haha
SpatzST
« Reply #4 on: February 03, 2014, 08:12:07 pm »
What type of wire do I need to successfully daisy chain the ground connector?
Generic Eric
« Reply #5 on: February 03, 2014, 08:20:03 pm »
Check this out   Project Arcade. Yours for the cost of shipping according to the details.
I was going to get a second copy to lend out, put you'll like it.
« Reply #6 on: February 03, 2014, 08:22:46 pm »
Groovy.  Are those Key Wiz or GP Wiz?
Asking because it's usually not that simple to use 2 key Wizzes since they use a PS2 connector and not all PS2 to USB adapters will work on them.
I think it's spoken for.  Haven't been paid yet, but not going to sell it out from under the guy.  You can be second in line if you want it.
It's a newer revised by BadMouth edition.
« Last Edit: February 03, 2014, 08:25:29 pm by BadMouth »
SgtSlaughter
« Reply #7 on: February 03, 2014, 08:31:50 pm »
I'm pretty sure most people use 18 guage wire.
mgb
  • North East, US
« Reply #8 on: February 03, 2014, 08:43:34 pm »
for daisy chaining the grounds to your switches, you may wanna use 22 gauge wire. you will need to have two wires in each crimp connection.
Slippyblade
« Reply #9 on: February 03, 2014, 08:48:57 pm »
I think it was Knievel that recommended the solid strand doorbell wire from Home Depot (or similar).
« Reply #10 on: February 03, 2014, 09:21:20 pm »
It was indeed! Excellent call, btw.
SpatzST
« Reply #11 on: February 03, 2014, 09:29:14 pm »
they are GP Wiz
SpatzST
« Reply #12 on: February 03, 2014, 09:30:59 pm »
what is it? also I don't see anything called project arcade in that thread.
« Reply #13 on: February 03, 2014, 09:42:41 pm »
It was a copy of Saint's book (Project Arcade) that I was giving away for free + shipping.
Hand edited by me to correct his orientation of P3 and P4 joysticks.
If you don't know what that's about, then don't build anything until you do.
http://newwiki.arcadecontrols.com/index.php?title=FAQ#Orientation
It's spoken for now, so I deleted the pics.  Not the best way to handle an item being sold, but oh well.
mgb
  • North East, US
« Reply #14 on: February 03, 2014, 09:55:32 pm »
a lot of guys around here will recommend sold wire because its easy to make neat but I wouldn't take that advice.
first off, thin gauge solid wire will break easier if its often moved or flexed.
second, crimp connectors are meant for stranded cable. Its very likely to get bad connections if used with solid.
If its any easier, the daisy chain connectors you need are also available already made from most of the vendors.
« Reply #15 on: February 03, 2014, 10:20:47 pm »
 :laugh2:
Slippyblade
« Reply #16 on: February 03, 2014, 10:26:05 pm »
The key words there being, "often moved or flexed".  Once the CP is wired, there should be zero movement or flexing of the wiring.  Also, I like to solder the wires to the lugs so the QD issue becomes moot.  Granted though, in a public cabinet, that I expected to get abused I'd use stranded wire and QD's to make it easier to swap out parts.
Generic Eric
« Reply #17 on: February 03, 2014, 10:27:29 pm »
Awkward.
I was linking to this book: http://www.amazon.com/Project-Arcade-Build-Your-Machine-ebook/dp/B004KAABVY/ref=sr_1_1?ie=UTF8&qid=1391484360&sr=8-1&keywords=project+arcade  It is worth a read even if you can't get it from Badmouth.
  • Online Online
  • Last login:Today at 02:50:56 am
« Reply #18 on: February 03, 2014, 10:34:51 pm »
+1000 to mgb's post.   :applaud:
There's a good reason why every arcade vendor I've seen uses stranded wire in their wiring harnesses and Atari used an even higher strand-count wire for the SW Yoke.
Prefab daisy chains FTW.
IF you decide to use solid core with QDs you may want to solder the wire to a hole in the QD for a solid electrical connection like Slippy mentioned and crimp the sleeve on the insulation for mechanical support.
mgb
  • North East, US
« Reply #19 on: February 03, 2014, 11:22:20 pm »
And truthfully, stranded wire is neater looking.
Generic Eric
« Reply #20 on: February 03, 2014, 11:35:16 pm »
Daisy Chain once, and you'll appreciate someone else doing it!
  • Online Online
« Reply #21 on: February 04, 2014, 12:09:58 am »
If you want to make the prefabs look neater (no left over QDs), use prefab daisy-chain (P) for all but the last connection (C) before a long run with nothing to ground.
         Encoder Ground
P---P---P---P---P                             P---P---P---P---P
P---P---P---P---C--------------------C---P---P---P---P
Player 1 (Joy + 6  buttons)          Player 2 (Joy + 6  buttons)
Highly recommended for cocktail setups.   :cheers:
SpatzST
« Reply #22 on: February 04, 2014, 11:56:26 am »
Thanks guys!
Il check out that book too
  • Last login:Yesterday at 06:17:10 pm
« Reply #23 on: February 04, 2014, 04:55:14 pm »
Buy a cheap JAMMA harness on eBay and use those wires. Much, much easier and cheap, too.
Unstupid
« Reply #24 on: February 04, 2014, 08:54:51 pm »
         Encoder Ground
I'd go like this:
                       Encoder Ground
P---P---P---P---C---------------C---P---P---P---P
mgb
  • North East, US
« Reply #25 on: February 04, 2014, 09:03:20 pm »
+1000
This is the best way
« Reply #26 on: February 04, 2014, 09:04:29 pm »
+1000
I think YOU gave me that idea, bro!
mgb
  • North East, US
« Reply #27 on: February 04, 2014, 09:05:56 pm »
No wonder I love that idea.
« Reply #28 on: February 04, 2014, 09:08:50 pm »
Imaginary Rep for you!
SpatzST
« Reply #29 on: February 05, 2014, 01:03:29 am »
another pic showing the intended layout. buttons are CLASSX with true leaf switches, happ competition sticks.  I need some cardboard to actually lay it all out.  does home depot sell large pieces of cardboard?
« Last Edit: February 05, 2014, 01:07:31 am by SpatzST »
Slippyblade
« Reply #30 on: February 05, 2014, 01:15:48 am »
Huh.  Pretty cool that the leaf switches are color-coordinated with the buttons.  Didn't know they did that.   :cheers:
  • Online Online
« Reply #31 on: February 05, 2014, 01:34:47 am »
Umm . . . You thinking about the bottom half of the CLASSX buttons, Slippy?
« Last Edit: February 05, 2014, 01:39:17 am by PL1 »
SpatzST
« Reply #32 on: February 05, 2014, 01:41:09 am »
stalking my photobucket? :D
Yes, PL1 is absolutely correct.  I actually had to insert each leaf switch into each bottom half of the button and screw it in.  I like that the piece comes off, should make assembling it into the control panel fairly easy.
  • Online Online
« Reply #33 on: February 05, 2014, 01:53:12 am »
Just clicked on the photo **that you hyperlinked to your PB account** to zoom in and see if Slippy was right.   :lol
The clear answer was in the next photo.   ;D
Slippyblade
« Reply #34 on: February 05, 2014, 03:29:57 am »
Yep, my bad.  Since the switch bits were not assembled onto the buttons, I assumed they were a separate piece.  Either way, kinda cool that they bottom parts of the buttons are matching colors versus just molding ALL the bottom bits from the same color plastic.
jdbailey1206
« Reply #35 on: February 05, 2014, 02:51:15 pm »
You don't even know how nice it is to have those leaf switches.  It makes it so much easier for troubleshooting and working on your panel.
SpatzST
« Reply #36 on: February 05, 2014, 10:44:54 pm »
So this is where I am at...
TopJimmyCooks
« Reply #37 on: February 06, 2014, 12:48:04 pm »
to settle this once and for all:
Solid wire - for connecting things that don't move.  for soldered connections.  for neater appearance on point to point.
stranded wire - for things that move.  for soldered or crimped connections.  Messy appearance unless you're good with planning, have a million zip ties, or can loom it up nasa style.
I like the leaf buttons.  Don't care for different colored players positions but to each their own.
Slippyblade
« Reply #39 on: February 06, 2014, 06:35:57 pm »
... or can loom it up nasa style.
Just curious, what do you mean "loom it up"?
