Author Topic: Mala + MameUI 152 = ESC problem  (Read 1325 times)
arcadeswede
  • Last login:February 15, 2025, 10:03:44 am
    • Revansch!
« on: February 02, 2014, 07:58:12 am »
Hello!
I use Mala as my frontend and MameUI152 (compiled) for launching games.
I can launch a game but when I press ESC to go back to Mala, I can't scroll or control anything in Mala.
I have to left click with the mouse or press Alt+Tab to somehow "activate" Mala again. It feels like the Mala window is behind something after exiting Mame but Mala is the only software running after exiting Mame.
Does anyone have a solution for this?
Re: Mala + MameUI 152 = ESC problem
« Reply #1 on: February 02, 2014, 08:54:29 am »
That is a common issue with Mala.
I would read through this thread, your solution is probably one of the things mentioned in here:
http://forum.arcadecontrols.com/index.php/topic,76882.0.html
There is also a plug in for download on page 1 from the ShanMan. I haven't used it, but I it should tell you what is activating instead of Mala when you leave games.
arcadeswede
    • Revansch!
« Reply #2 on: February 02, 2014, 02:46:17 pm »
Thank you so much for the link!
That plugin solved my problem :)
This thread can marked as solved.
