Author Topic: Jammaboards.com Pacman to Jamma and JPac weird button issues???  (Read 1366 times)
jtslade
  • Last login:February 13, 2025, 10:06:51 pm
  • Keep it looking originallish!
« on: January 26, 2014, 05:28:34 pm »
So I have my ms. PAC cocktail
It's pc mobo to JPac to Jamma boards Pacman to Jamma converter..
Then converter edge connector to the harness of the Ms pacman cocktail arcade. This is all non destructive btw..
I have the Jamma boards dip switches on 1-3 and 2-4 which disable the player 1 start button to be used at fire..
On my cocktail control panel I have two buttons wired up straight to the jamma boards button one and two..
The start buttons and 4 way stick are standard..
Problem is that when I hit button one it registers 1 and 2 At the same time which in groovy Mame registers as Left Cntrl and left Alt at the same time. Vice versa is the same as well..
Wired thing is that player one start and player two do the exact same thing..
4 way controls work perfectly..
The self test light on the JPac is solid on.
Any thoughts, is a board defective or did I wire up something wrong or put the ground wire to the wrong spot on the Jamma to pacman adapter??
Any ideas, very weird ?,
Ms. Pacman Original Cocktail with Non destructive mod to Groovy Arcade Linux with All 4way Vertical Cocktail capable 2 button or less games.
Neo Geo MVS Mame Cab Running Hyperspin, 25" Nanao Arcade Monitor, Mini-pac, ATI Radeon HD 4850 (ATOM-15), IL 8 Way Euro-Sticks from Paradise Arcade, Win XP 64bit, and tons of other junk.
jtslade
Re: Jammaboards.com Pacman to Jamma and JPac weird button issues???
« Reply #1 on: January 26, 2014, 09:06:34 pm »
I'm leaning toward a ground issue?
j2obin
  • Last login:March 12, 2015, 02:10:20 pm
« Reply #2 on: January 26, 2014, 09:29:19 pm »
I had the same issue with my Ms Pacman upright.  Jumpers worked fine as long as you want the player 1 and 2 buttons to act as fire buttons but the setting that was supposed to disable this behavior did not work properly.
After following the traces on the board it was obvious this would not work as documented.  I discovered you needed to disregard the instructions and remove both jumpers.
jtslade
« Reply #3 on: January 27, 2014, 09:46:52 am »
I'll try that, thank you
jtslade
« Reply #4 on: January 27, 2014, 12:19:20 pm »
That was it, works perfectly now.
Thank you bigtime!
