Author Topic: DK joystick replace, or repair?  (Read 2736 times)
Sarver Systems
  • Last login:October 07, 2020, 12:46:05 am
« on: January 24, 2014, 02:02:04 pm »
I've got a DK machine. The small swivel bearing inside the joystick has quite a bit of rust on it, causing the joystick to not spring back to center, and to be hard to move in any direction.
I took it apart, cleaned the joystick shaft, sprayed some WD40 on the bearing, and that brought it back to about 80% of perfect.
Now I'm considering just repalcing the joystick altogether.
Any suggestions? I'd like to keep it as stock as possible, so I'd like to stick with an exact replacement using the existing leaf switches.
Re: DK joystick replace, or repair?
« Reply #1 on: January 24, 2014, 03:27:56 pm »
Try Mike's Arcade.  He stocks a number of parts to repair a DK joystick.
chopperthedog
  • Last login:Yesterday at 09:48:21 pm
« Reply #2 on: January 24, 2014, 05:24:46 pm »
Look for a populated vs control panel and use the base from player 2 and transfer parts over.
Don't use wd40 anymore. In the future use a can of brake cleaner on that bushing/base and when dry use a teflon based lube.
Mike's isn't what it used to be. I think we can stop doing the "try mikesarcade" posts.
good day.
« Last Edit: January 24, 2014, 05:27:19 pm by chopperthedog »
« Reply #3 on: January 24, 2014, 10:03:47 pm »
good day.
Did he screw someone of are you just saying that because he doesn't stock as much as he used to?
« Reply #4 on: January 24, 2014, 10:15:48 pm »
I've bought twice from Mike's in the past five months and been pleased. What were you looking for?
chopperthedog
« Reply #5 on: January 24, 2014, 10:31:30 pm »
Well, for Nintendo joy parts, CP/coin bolt stuff it has been out of stock for over a year (glad what I needed was there in 2011 >:D ) . I did get a nice Nintendo audio and video cable for the sanyo ez from them a month ago though.
good day.
