Author Topic: Ultimarc RGB classic buttons  (Read 2912 times)
seanr28
  • Last login:August 22, 2017, 07:47:31 am
« on: January 24, 2014, 01:36:16 pm »
Who has them?
I have just received 20 of them, and must say I honestly not impressed with them at all.
The feel very cheap in deed
when the LEDs are in place the wires are crushed against the Microswitch as there is no actual place for them to go
and when its all back together the buttons don't feel right and the movement is restricted because of the wires.[/li][/list]
personally Im wishing that I had just purchased illuminated colored buttons
Looking at them, the only way to overcome this issue would be to drill the bottom side of the buttons where the microswitch sits and have the wires route via the new hole
any thoughts?
« Last Edit: January 24, 2014, 01:39:53 pm by seanr28 »
  • Last login:Today at 12:52:09 am
Re: Ultimarc RGB classic buttons
« Reply #1 on: January 24, 2014, 04:35:05 pm »
any thoughts?
I do that with IL Transluscents all the time. It's preferable.
lamprey
« Reply #2 on: January 24, 2014, 09:35:53 pm »
I don't have any experience with those buttons as I went with the Electric Ice 2 push buttons. But, are you saying the light is further up inside so the act of pushing down the button rubs on wires? If so, then you might want to look at the EI2 buttons in combination with the RGB Drive II light.
Spastic
  • Last login:November 22, 2015, 07:37:06 pm
« Reply #3 on: January 24, 2014, 09:54:20 pm »
I've got them in my cabinet.  I had the same issue as you initially, where they felt really mushy with the LED installed.  I fixed it by pressing the button down as I snapped the switch into place over the cable.  That way the LED is below the buttons even when they're at the bottom of their throw.  That made them feel the same as without the LED for me.
seanr28
« Reply #4 on: January 25, 2014, 03:32:53 am »
they would have been better.  Too late now though as I have just got 20 of them, shame, it put me off the Ultimarc stuff in the future.  I can believe how poor quality these things are.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #5 on: January 27, 2014, 08:10:19 am »
These buttons are made by Industrias Lorenzo who make buttons for Happ and others. They are top quality. They do already have a hole drilled for the wires.
I suspect you have not assembled them correctly. The usual issue is the diffuser not being pressed fully over the LED.
They should be identical in feel to a Happ button as they are identical but only if assembled correctly.
If you can send an email andy@ultimarc.com I can assist further.
seanr28
« Reply #6 on: January 28, 2014, 09:05:59 am »
Andy,
Thanks for you response, They are assembled correctly and the wires go through the whole in the bottom center of the button casing, the issue is routing the wires once the micro switch is in place.  Using the method stated on your website just seems to crush them.  I have since routed them around the edge and seems to be ok now.
regards
sean
