Author Topic: paint selection..  (Read 1901 times)
PixelPaul
  • Last login:November 03, 2025, 02:06:10 pm
paint selection..
« on: January 23, 2014, 08:02:26 pm »
I'm curious as to what the best paint for arcade cabinets is? Flat, eggshell, satin, semi-gloss, gloss? I would think the the outside surfaces should have something with some sheen to it, but flat black would be better for the inside? In regards to black paint for most projects in the past I have just picked up a quart can of rustoleum, but I think that would be to glossy for this purpose. Can the paint counter at Home Depot mix black paint like they do the other colors? I guess I've never noticed black swatches in the paint aisle.
Slippyblade
Re: paint selection..
« Reply #1 on: January 23, 2014, 08:22:24 pm »
Yes, Home Depot will mix black for ya.
michelevit
  • Last login:December 25, 2024, 06:57:41 pm
« Reply #2 on: January 23, 2014, 08:52:07 pm »
My paint of choice has been oil based satin black by rustoleum. Comes in a can for about 10 bucks. I thin it with acetone or laquer thinner and spray it with a hvlp gun. Lays down great and provides a durable oem looking finish. Available at home depot, lowes or osh. I also use this paint for the backside of the bezel.
RabidRabit
  • Last login:January 28, 2018, 03:09:43 pm
« Reply #3 on: January 23, 2014, 09:51:16 pm »
When you say the "backside of the bezel" are you talking about the glass that your monitor sits behind?  The reason I ask is because I bought that exact paint (Rustoleum Satin Black) to paint my kickplate and was wondering if it would do well for the bezel glass as well.
michelevit
« Reply #4 on: January 24, 2014, 11:04:24 am »
yes. i use the same paint (rustoleum satin black) to paint the back of the monitor bezel. I also use it to paint the actual monitor frame itself.
Here is a pic...
Its not actually glass but plexiglass from tap plastic. The painted side sits facing the monitor. I mask with blue painters tape cut with a new sharp razor.
« Last Edit: January 24, 2014, 11:06:23 am by michelevit »
michelevit
« Reply #5 on: January 24, 2014, 11:07:45 am »
here is a pic of the monitor being masked and painted.
  • Last login:Today at 12:10:06 pm
« Reply #6 on: January 24, 2014, 11:25:56 am »
If you're painting a cab red use dark primer, not white.
I didn't learn about that until after it took 10 coats to get the color even.
I've read that black paint mixed at the store won't be as dark as special order black paint.
I've only used the mixed stuff and am satisfied with it.  It was either semi-gloss or satin, don't recall which.
Had both the Neo Geo red and black mixed at Lowes.
Kier
  • Last login:July 20, 2019, 07:40:00 pm
« Reply #7 on: January 24, 2014, 08:28:50 pm »
This. Rustoleum black satin. Great finish.
FNwoz
  • Last login:June 19, 2015, 03:38:09 pm
« Reply #8 on: January 25, 2014, 11:12:30 am »
I read somewhere this is a really good paint to go with. I am about to paint my cab and I was going to start with this to see how it looks. Any thoughts compared to the satin?
http://www.homedepot.com/p/Rust-Oleum-Painter-s-Touch-32-oz-Semi-Gloss-Black-General-Purpose-Paint-1974502/100208855
