Author Topic: problem with HD 3300 and HD 4850 Radeons  (Read 3642 times)
Ibaroh
  • Last login:September 29, 2015, 03:04:08 am
« on: January 22, 2014, 03:47:59 pm »
Hello,
I have the problem to get only a useless scrooling picture with cards that actually should work (HD 3300 and HD 4850). Against that a X1050 Card works well.
I already tried many things like clean reinstall the drivers, change operating system, change minimum clock, change Monitor Presets and switch DVI ports but can't find a way to fix the problem.
My setup is a XP computer, VGA to SCART Adapter to a PAL Tube.
Maybe somebody has an idea?
Sorry for my bad english
Sledge
  • Last login:August 02, 2025, 01:37:53 am
Re: problem with HD 3300 and HD 4850 Radeons
« Reply #1 on: January 22, 2014, 05:02:29 pm »
Tried adjusting the v-sync pots?
  • Last login:Yesterday at 06:10:10 am
« Reply #2 on: January 23, 2014, 09:53:57 am »
Are you possibly using CRT Emudriver 9.3 for x64? If so, make sure to run vmmaker after installation.
Ibaroh
« Reply #3 on: January 23, 2014, 10:25:41 am »
what is to do for it?
I try the 9.3 32 and 64 version and run vmmaker. Also other methods like Soft-15KHz buts its alwas the same bad result.
« Reply #4 on: January 23, 2014, 10:41:38 am »
Do you trust your VGA-SCART cable 100%? It looks like a problem with the sync signals (even if it does work for the X1050)
Ibaroh
« Reply #5 on: January 23, 2014, 12:15:10 pm »
not 100% but it is a cable from a german arcade shop special for this purpose.
is there maybe a smart way to test it for errors without buying a new one?
edit: organised an other vgs/scart adapter for next week to test
« Last Edit: February 17, 2014, 10:04:41 am by Ibaroh »
« Reply #6 on: January 25, 2014, 04:27:06 pm »
Before ordering a new cable, maybe I'd check the signal on a PC monitor that has a good OSD, so it can report the output frequency.
Ibaroh
« Reply #7 on: February 17, 2014, 10:02:03 am »
Today I got a new Scart/VGA adapter and it works perfectly. :banghead:
big thanks for your help
« Reply #8 on: February 20, 2014, 10:08:44 am »
Good to know, anyway.
