Author Topic: Black screen on arcade monitor after Windows boots -- What am I missing?  (Read 3873 times)
Bimmy
  • Last login:November 09, 2025, 07:25:18 pm
My setup:
- Windows XP
- Asus HD 4350
- J-PAC with jumper on 15khz only
- arcade cab with standard res monitor, vertical
I followed cools' instructions word for word.
(however I found a discrepency: the instructions say to change monitor type in VMMAKER.INI to CGA, but that isn't a valid value according to the notes. So I tried NTSC but same black screen.)
Before rebooting, I set the resolution to 640x480.
After that, I connected the PC to the J-PAC and rebooted.
I saw the Windows loading screen with terrible roll.
After that, black screen.
Note that I can remote desktop into the PC and see what I'm doing while the PC is connected to the J-PAC.
cools
  • Last login:August 19, 2025, 04:19:37 pm
  • Arcade Otaku Sysadmin
    • Arcade Otaku
Re: Black screen on arcade monitor after Windows boots -- What am I missing?
« Reply #1 on: January 17, 2014, 12:09:01 pm »
cools
    • Arcade Otaku
« Reply #2 on: January 17, 2014, 12:10:43 pm »
Also, nowhere do I say to change the resolution by hand. That's probably what's screwed you up. Run vmmaker again to set the mode and try rebooting immediately after?
  • Last login:Yesterday at 10:59:40 am
« Reply #3 on: January 17, 2014, 12:17:52 pm »
Hi Bimmy,
Use the DVI-I output. (with a DVI to VGA converter)
Bimmy
« Reply #4 on: January 17, 2014, 07:54:59 pm »
My PC identifies the VGA port on the 4350 as "Monitor 1". It's what I've been using to set up the PC.
When the arcade cab is connected to VGA, I can see the boot screen (with terrible H or V roll). Then goes black when Windows is loaded.
When connected to DVI, I get no picture at all, not even boot screen.
I ran VMMAKER.EXE again and rebooted immediately after. Same result.
My PC monitor continues to work fine, so that tells me there is no 15khz signal being output?
 :cry:
Sledge
  • Last login:August 02, 2025, 01:37:53 am
« Reply #5 on: January 17, 2014, 09:33:36 pm »
Is the sync light coming on on the jpac?
Bimmy
« Reply #6 on: January 17, 2014, 09:40:21 pm »
VGA:
self test = solid green
sync in = solid yellow
sync ok = not lit
DVI:
sync in = "strobing" yellow
sync ok = not lit
Bimmy
« Reply #7 on: January 17, 2014, 11:01:23 pm »
I've made progress.
Are you supposed to be able to see the Windows desktop? It's a black screen for me. But I can run and see MAME games.
But...
I can't get the damn picture to hold. I've twisted every pot on the monitor chassis. In addition to not holding, it's flickering like a fluorescent light. Something I've never seen before... not a typical hold issue.
The J-PAC SYNC light is flickering.
 :banghead:
Bimmy
« Reply #8 on: January 18, 2014, 12:59:09 am »
More progress, but it's getting stranger.
At one point, it was working perfectly. The image was holding, and Windows displayed on the monitor at 640x480.
I don't remember what I did. I was just switching back and forth from the PC monitor to arcade monitor, trying various resolutions. Once I got it, I wanted to see if I could reproduce it by rebooting. Nope.
Now I am back to black screen at Windows desktop. Furthermore, MAME no longer runs on the arcade monitor like it did before. I keep getting SwitchRes: could not find mode... error. I also saw a Direct 3D error once. Something about it couldn't write to a file.
I've run VMMAKER.EXE several times, rebooted, with same result.
Bimmy
« Reply #9 on: January 18, 2014, 01:36:55 am »
I can reproduce:
1) Boot PC connected to PC monitor.
2) Switch res to 1366x768 (native)
3) Start MAME
4) Unplug PC monitor
5) Plug in arcade monitor
6) Play beautiful games
If I shut down the PC, I need to repeat these steps. Rebooting with the arcade monitor connected results in the black screen.
I guess I can just leave the PC running for extended periods of time, but damn it's annoying. Any advice?
Sledge
« Reply #10 on: January 18, 2014, 02:34:58 am »
Checked that the drivers are actually installed?
Nothing in device manager showing as not installed?
« Last Edit: January 18, 2014, 02:37:42 am by Sledge »
