Author Topic: emulator image in the Mala tree?--SOLVED  (Read 4438 times)
bsellers100
  • Last login:June 19, 2018, 05:46:46 pm
« on: January 16, 2014, 06:19:43 pm »
ok, I have my emulators set up and running fine, and I have the tree setup and running as well.  The problem is that I can't get the emulator images to show up in the tree when I scroll down the list.  I have the background image showing fine, and I have the images named main menu_mame.png or main menu_super nintendo.png as per the instructions, but nothing shows up on the background.  Do these images need to go in a certain folder?  Does the layout file need this to be a snap, or a marquee, or something else?  Any help here would be appreciated.
« Last Edit: January 17, 2014, 11:56:43 pm by bsellers100 »
bsellers100
Re: emulator image in the Mala tree?
« Reply #1 on: January 17, 2014, 11:50:10 pm »
ok, I figured out the problem.  The Mala wiki is incorrect.  If anybody can get into the wiki to correct, this is the issue:  Per the wiki, the tree snaps need to be in the format:
"Main Menu
  |_Nes
  |_Game Boy
The filenames for the snaps should be:
main menu_game boy.png "
In actuality, the snaps should be named mala menu_nes.png and mala menu_game boy.png, NOT main menu_nes.png as the wiki says.
Hopefully this will help out somebody else that is having problems, and maybe somebody that can access the wiki can add this info.
l0ck0
  • Last login:April 14, 2020, 03:38:59 am
Re: emulator image in the Mala tree?--SOLVED
« Reply #2 on: September 05, 2014, 04:09:34 pm »
first sorry if lake is not understood. I'm using the google translator :(
are you sure that it works well as you say? I carry on trying days and no way.
I have the menu so
Menu Principal
- Arcade
----- Mame
----- Naomi
- Sega
----- GameGear
----- Master System
- Nintendo
----- NES
----- GameBoy
----- GameBoy Advance
- Sony
----- Psx
----- PS2
and have proven all kinds of convinations. menu_arcade.png Menu_Arcade.png Menu_arcade.png menu_Arcade.png principal_arcade.png Principal_Arcade.png Principal_arcade.png principal_Arcade.png .....
I've also tried to change the Menu Principal for Main Menu like in the example but does not work me
