Author Topic: Groovy arcade button combo for system shutdown from front end?  (Read 2722 times)
jtslade
  • Last login:January 22, 2026, 03:19:42 pm
  • Keep it looking originallish!
« on: January 15, 2014, 06:56:29 pm »
Anyone know how to setup a system shutdown from a button combo?
Ms. Pacman Original Cocktail with Non destructive mod to Groovy Arcade Linux with All 4way Vertical Cocktail capable 2 button or less games.
Neo Geo MVS Mame Cab Running Hyperspin, 25" Nanao Arcade Monitor, Mini-pac, ATI Radeon HD 4850 (ATOM-15), IL 8 Way Euro-Sticks from Paradise Arcade, Win XP 64bit, and tons of other junk.
  • Last login:January 23, 2026, 06:10:10 am
Re: Groovy arcade button combo for system shutdown from front end?
« Reply #1 on: January 17, 2014, 04:13:56 pm »
It's possible to setup a key in advmenu.rc to shutdown your system, we  had it like that for some time. I can't remember now the exact option, but it's there. I don't know if key combos are possible either.
« Last Edit: January 17, 2014, 04:31:20 pm by Calamity »
blontic
  • Last login:December 21, 2020, 08:03:28 am
« Reply #2 on: January 17, 2014, 04:29:31 pm »
You can also set it to shutdown on exit instead of going back to the groovyaracde menu
duke_of_earl
  • Last login:February 06, 2014, 05:10:24 am
« Reply #3 on: January 18, 2014, 06:53:02 pm »
The shutdown key option for AdvmenuPlus on advmenu.rc is this:
event_assign shutdown lcontrol esc
With the default configuration, pressing left control key + esc should shutdown the system. Nevertheless, for some reason, it didn't work for me, so I changed it to other key. It shuts the computer down without going to the setup menu. You could assing that option to whatever key combo your input system would use for shutdown.
