Author Topic: atomic fe layout question  (Read 1591 times)
dcninja
  • Last login:March 01, 2025, 09:59:52 am
« on: January 14, 2014, 07:24:28 pm »
I have a bunch of atomic fe layouts and I want to change my main layout from the stock one to a different one but I have no idea how to get it to use my new layout. Any help would be appreciated as I can't find anything googling around. THANKS!!!!
  • Last login:Today at 01:26:35 am
Re: atomic fe layout question
« Reply #1 on: January 14, 2014, 08:42:09 pm »
When you set up your emulator screen, at the bottom there is a pull down where you can change the layout. Make sure you put all the layouts in the same folder.
dcninja
« Reply #2 on: January 14, 2014, 09:26:23 pm »
what do you mean when i set up my emulator screen. i have an exe and i launch it. there was no setting up the screen outside of me editing paths in cfg files.
dcninja
« Reply #3 on: January 14, 2014, 09:37:52 pm »
atomic fe is also showing a few games out of order and refuses to show galaga or galaxian. wtf is going on?
« Reply #4 on: January 14, 2014, 09:49:05 pm »
Didn't you use AtomicStudio to set it up?
dcninja
« Reply #5 on: January 15, 2014, 03:55:37 pm »
i didn't see that in my download :(
« Reply #6 on: January 15, 2014, 04:18:52 pm »
It should be part of the regular install. Look for AtomicStudio.exe.
dcninja
« Reply #7 on: January 15, 2014, 05:31:36 pm »
i tried it. all i want is to use mame, to have my files listed in alpha order (some are off) and to use a custom layout.
I can't get any of that to work in the atomicstudio thing. It looks like a skin creator not a front end setup tool. :(
