Author Topic: GroovyArcade Boot Screen crash  (Read 1819 times)
BeeryGaz
  • Last login:February 01, 2014, 10:17:11 am
« on: December 27, 2013, 06:00:03 am »
I'm using GroovyArcade installed to a HDD - it's working like a dream but I have one issue. If I enable the Grub boot logo, I get a split screen image of the GroovyArcade logo, it animates for a while, a small purple box shows up with what appears to be a progress bar and then everything locks up (And the logo animation stops).  If I disable the boot logo everything is fine, the screen quickly switches from the 30Hz split screen effect to a normal image.  On shutdown the logo appears correctly.
Any ideas on how to address this?  (Radeon X800 & generic 15Hz monitor)
duke_of_earl
  • Last login:February 06, 2014, 05:10:24 am
Re: GroovyArcade Boot Screen crash
« Reply #1 on: December 28, 2013, 02:41:50 pm »
It seems to be a known problem, the splash screen on boot somehow corrupts the graphics card. I think the only solution is to keep the splash screen disabled on boot.
ves
  • Last login:April 11, 2020, 02:57:49 am
« Reply #2 on: December 28, 2013, 03:30:09 pm »
Hello, you can fix boot splash, following these steps
Edit file /etc/mkinitcpio.conf
Add MODULES = "radeon nouveau"
Execute command
mkinitcpio -p linux && reboot
